Steering damper recall notice today on my Jeep
Joeymon1
Southern Tier, NYS
2019 Sahara
Just had the recall done on my Jeep last week. Did not have any wandering or dead spots but did have the wobble after bumps at highway speeds.
Noticeable difference after recall -installed properly.. No more wobble and a little tighter and better than new.. Hope it lasts
Attaboy55
Tallahassee
2019 Jeep wrangler jl 2 door firecracker red
Just had mine replaced, upside down as well. How on earth can they put it on upside down with an arrow to show the proper orientation?
because ut would not FIT properly in the correct position , I'm going in Monday to have their fix of a new bracket which , according to them will allow it to be put on correctly, I assume the bracket on there now, will not accomodate with "BULGE" downwards...Based on many upside down Mopar 580AE's it would appear the AE will not fit properly using an older stock bracket....
jloyva
Jim
Savage, MN
Sting-Gray Wrangler JL Sport S, Victory Touring Cruiser, Kia Sorento
Project Manaager
It fits just fine in the correct position. It's just a matter of untrained and/or inattentive service techs.
Attaboy55
Tallahassee
after recognizing upside down went to dealership, they said nimrod couldn't install it properly because bad bracket and would not fit in the correct position , so he mounted it upside down, which they oredered, this is all I can go by, otherwize a 180 flip would have rectified this....
Attaboy55
Tallahassee
and yes I agree should have NO PROBLEM putting on the new SS, however i wonder if some brackets ARE different, based on alot of variables, still piss poor work, shoulda said up front " won't fit ..bad bracket , one on order, but these jacklegs twist and go thie merry way.
bgj1010
Brandon
Millbury, MA USA
2018 Wrangler JLU Sport S
Systems Engineer - Manager
Well, they did it to mine Monday as well. Need to check for the bulge in bottom when I get home later. How friggin hard is it to perform a 2min install?!
DrDee
New York
VW Beetle 2003, Sahara 4 door Silver 2020
Ok folks, this is it I’m going to dealership tomorrow 7:30 am (an ungodly hour) for same with weird steering. Took out air from tires to 36-37 psi. I’m NOT mechanically inclined, how would I know where to look if they place part wrong? What should I say, when I arrive?
Thanks
Rdmitch
Ross
Elyria, Ohio
2020 JLUR, ford transit 250, 2017 Wrangler Smoky Mountain Edition
Mechanical designer /contractor and musician
Thanks
Have you been there before on this issue ?
Rdmitch
Ross
Elyria, Ohio
How is it handling ?
x3L
GB, WI
2018 MOJITO! JLUR 2.0
Just got mine done, forgot to look at the dealership but mines upside down as well. What’s the culprit on this? They supplied a recall for a product that needs a different bracket they didn’t supply with the recall???
Rdmitch
Ross
Elyria, Ohio
Are you thinking it’s upside down based on the sticker or the vent “bulge”.?
Jimac
Jim
Kingston, OK
1979 CJ-5, 2018 JL Rubicon red leather pst steel tow keyless remote painted flares auto 1-24-18
No different bracket just installed upside down. Bolts and nuts one time use. Stayed in instruction if driven in this condition then actuator and hardware to be replaced.
Rdmitch
Ross
Elyria, Ohio
the sticker is insignificant, if the bulge (the little bubble vent) is on the bottom its installed correctly.
According to FCA the bulge on bottom trumps the sticker.
Please correct me if I'm wrong, but this info came out on a recent bulletin.
Rdmitch
Ross
Elyria, Ohio
TopLift Pros
