mwilk012
They won’t / aren’t allowed to. The boxes are “not adjustable”.Thats the plan. I need to figure which lca's would be best. Wonder if i should first have dealership try to adjust the steering box first?
Thats odd.. I believe it shows in the TSB an adjustment nut on top of the box. Almost positive it does.They won’t / aren’t allowed to. The boxes are “not adjustable”.
It for sure has the nut. I broke the nut loose but can't turn the inner screw. I've given up on the dealer fixing this problem so wanted to try it myself. I don't have a 5/32 allen socket. Can't get enough leverage with the allen key.Thats odd.. I believe it shows in the TSB an adjustment nut on top of the box. Almost positive it does.
Of course it has a nut there. However it is “not adjustable”. Emphasis on the quotes.Thats odd.. I believe it shows in the TSB an adjustment nut on top of the box. Almost positive it does.
Not doubting what you stated, but i have watched a few videos on the early JL boxes being adjusted. Are you referring to the latest "AB" boxes as being non-adjustable? I have the latest AB box now.Of course it has a nut there. However it is “not adjustable”. Emphasis on the quotes.
I don't think you're following. It is "not adjustable".Not doubting what you stated, but i have watched a few videos on the early JL boxes being adjusted. Are you referring to the latest "AB" boxes as being non-adjustable? I have the latest AB box now.
