Steering Box flexing when turning the wheel
swissspeed
andrew
ohio
2018 jlu unlimited and 2020 rubicon 2 door
I just received 2020 JL Rubicon, I notice the steering really got loose at 71 miles. Took it back to the dealer and they replaced the steering box..... no change. I took it back again and they found that the steering box is flexing / distorting when the wheel is turned while stopped. Has anyone else seen this and do you know of a fix?
JEEPIDON
Charlie
Forsyth, Missouri
2018 Wrangler Rubicon JL, 2018 Wrangler Sahara JL, 2010 Dodge Challenger R/T, 2013 Ram Longhorn 2500, 2008 JK Wrangler Sahara
Retired - Business Consultant
Andrew, I just looked and mine does not flex or move. 2018 Rubicon.
AZCrawl
AZ
2018 Granite Jeep JLUR
swissspeed
andrew
ohio
AZCrawl
AZ
I have a stock rubicon, I am concerned that with stock tires that if it flexes under this load what will it do on the trail or if I put bigger tires on it. After dropping 50K, I think the steering box should be able to hold the stock tires..... am I wrong?
You aren't wrong. If you are planning on keeping it stock, then I would take it to the dealer to complain and have them address the issue. If you plan on putting bigger tires on at some point, then this will take care of the issue now and as well as when you put bigger tires on.
swissspeed
andrew
ohio
Thanks I am just trying to get it to the best starting point before I start the upgrades..... plus I wonder how many people are driving around with this issue and dont know it. My belief is that if this continues to flex over time it will fail.
AZCrawl
AZ
Yeah, it all depends on what you are planning to do long term. I put the Synergy bracket in and later went with the PSC Big Bore Hydro Assist steering kit, still have the bracket, but the steering box shaft won't fit. :LOL:
Rock Krawler
