MyDaughters20JL
Bought this Bar direct from Australia a couple weeks ago: had it mounted briefly, but was not happy with the way the Zroadz brackets partially covered the windshield; both from the aspect of windshield replacement as well as replacement/layer removal of my laminated tear-off.
Never been wired up, but if it's anything like my 22" Stedi bar, the light will be unbelievable
Deutsch connector has been removed from light wire and about 8' of dual conduit 14GA wire has been added.
All included brackets, screws and wiring harnesses included.
this is for the light bar ONLY: Zroadz brackets NOT included
PERFORMANCE THAT LETS YOU TURN THE SUN BACK ON
BUILT TO GO ALL NIGHT
MOUNT IT YOUR WAY
We know you want flexible mounting options, which is why we’ve included two separate mounting options.
$350
LED MANUFACTURER | OSRAM (Oslon) ® |
LED COUNT | 100 |
VOLTAGE | 12V & 24V |
LENS MATERIAL | OPTICAL GRADE, HARD COATED LEXAN |
LUMENS | 24,000 LUMENS |
PEAK INTENSITY (CANDELA) | 1,104,000cd |
HOUSING MATERIAL | A360.0 Cast face plate, extruded Aluminum heat sink |
AMPERES | 23.4.2A @ 13.6v |
LIFESPAN | 50,000 |
FLOOD BEAM | 50° |
SPOT BEAM | 5.8° |
INGRESS PROTECTION | IP68 |
OPERATING TEMP | --40°C to 60°C |
WEIGHT | 6.620kg |
- STEDI ST4K-100 features 100 of OSRAM’s® finest OSLON® LED, selected for its high luminous flux and perfectly match optical properties.
- 16 Flood + 68 Spot + 16 Flood reflector distribution forms a remarkable beam that pushes the wide beam out at 50° and spot beam at 5.8° all the way to staggering 1 lux @ 1,050m
- Crystal White 5700K Colour temperature offers stunning clarity and definition with excellent Colour Rendering Index (CRI).
- Our Pure-Drive™ circuit design allows 97% of input power to go directly to LEDs.
- A360.0 Cast face plate extruded Aluminium heat sink| finished in 100% Polyester UV and abrasion resistant powder coat, ensures that our bars will never discolour.
- Pressure Equalization vent with Gore® membrane | Protects against water ingress, dust & contaminants.
- IP68 | Dust & Particle tight + Water-proof up to 3 meters – Drown it, we insist!
- Environmentally sealed Deutsch ® DTP connector.
MOUNT IT YOUR WAY
- The included adjustable sliding mounts allow you to align the mount bolts to any pre-existing mounting holes. Make mounting to UHF tabs or Bull bar dech very straight forward.
- Or use our 3mm thick 304 Stainless steel side brackets, which feature + or - 15mm height adjustment.
$350
