Start of 3.0 Production
NW_Jeep
Spokane Washington
2020 JLUR
Well I guess gears could be on upgrade list. With the torque I’m hoping I’ll be fine on 38’s but I guess I’ll get the gears I want
MNMJD
Michael
2020 Wrangler Unlimited Rubicon 3.0L
Not sure if this has been posted yet - if duplicate sorry
Eeshasdon
Don
WA
2020 Diesel Rubicon
As most of us know the diesel will have a different trans than either the 2.0 or the 3.6 (3.0- 8HP 75 vs 8HP 50 for the other two). Here is a chart showing the differences in gearing, in case anyone is interested.
Jaddie
Jaddie
Buford, GA
2012 Honda Odyssey
I wish my mechanical knowledge was sufficient enough to understand that table.
So is 8HP 75 more betterer than 8HP 50?
BuffaloBill
Bill
WI
2018 Wrangler, 2014 Ram 1500 EcoDiesel 2020 JLUR Ecodiesel
If you wanted to calculate for example, the engine rpm in 8th gear for say 60mph, it’s pretty straightforward:
The tire info for the stock Rubicon K02 tire shows 635 revolutions/mile (tirerack’s data).
60mph is 1 mile/minute.
Therefore a tire rpm of 635 would produce 60mph.
With 3.73 axle ratio, the drive shaft spins 635 X 3.73 = 2369rpm (rounding up).
From that table, the overall trans ratio in 8th is 0.64.
So the engine rpm then, is 2369 X 0.64 = 1516rpm.
Any other speed would just be a ratio of the above. If traveling 75mph, the engine rpm would be:
(75 x 1516)/60 = 1895rpm
I imagine the tire mfg’s data might be at rated load and pressure? The load and pressure we run on the JL might result in a slightly different rev/mile. But I think that effect would be small. At higher speeds the rev/mile decreases a tiny bit also. But I’d expect the real life rpm to be pretty close to calculated.
Are they building our Jeeps yet?
JLURD
JLURD
Alaska
2018 Compass Latitude 6MT, 2020 JLUR 3.0
75 is good for 750Nm of torque, 50 is good for 500Nm. The 75 will have different software to tailor the shift points to an engine with lots of low-end torque. Other than that, essentially the same transmission.
JLURD
JLURD
Alaska
No and they probably won’t until the EPA/CARB certify the emissions/fuel efficiency.
BuffaloBill
Bill
WI
Yeah, when on Jeepchat yesterday I asked if they had any insight on the epa date. But they did not.
Eeshasdon
Don
WA
2020 Diesel Rubicon
Just found this on the CARB website. It is dated today but the doc is dated 10/17. Can somebody smarter than I, tell me if this is what we are waiting on?
JLURD
JLURD
Alaska
Executed 10/1 re CARB emissions certification. Seems the EPA fuel efficiency certification is the only missing piece at this point then. Would be interesting to know how many other vehicles are “deficient” in CA’s OBD requirements and paying fines to the tune of hundreds of dollars per vehicle. Would also be nice to know how egregious the requirements are (likely very given the millions in fines) and how it’s being baked into the cost of every vehicle.
Jaddie
Jaddie
Buford, GA
2012 Honda Odyssey
Thanks for this. I saved this in my note-keeping app for future reference.
