Molson123123
You can get a harness from here:I have the same 7" non-Alpine head unit. I don't recall whether the amp, on its own, is pure plug 'n play, as the system I am currently using it in came with harnesses that made mine plug 'n play. Check with Crutchfield; they may have a harness that makes installation of this amp plug 'n play.
And remember, while increasing power to the stock head unit will help, upgrading speakers and adding a sub woofer is really necessary to get greatly improved sound. You don't have to do all the speakers; just upgrading the dash tweeters to get better highs (which is a 10 minute swap) and adding a sub to boost bass lows will make a great difference when combined with the KTP amp.
https://www.pacparts.com/library/model.cfm?mfg=Alpine&model_id=PSS23WRA&action=list_part&back=0
It’s actually for the amp as well as the alpine under seat sub (comes packaged as PSS23 WRA for the sub and amp and harnesses). I’m not sure whether the harness can be used just for the amp, but if so, this is as “plug and play” as you’ll ever get.
