dannko
- Dan
- Aug 14, 2018
- Bee Cave TX
- 2018 Rubicon JL Unlimited
I am leaning to the right appx 3/8-1/2". I have the Mopar lift. I retorqued the entire suspension, it may have helped a 1/8".
It appears as if the lean is coming from the RH rear spring. As if I lift that only a little it will also lift and transfer weight to the LH front, technically leveling it out.
Is there any kind of shim/spacer appx 1/8" that I could install under the rear spring isolator? Either on top of the current isolator or the bottom of it? The factory isolator is basically a round bumpy level perch, so I need like a huge flat plastic washer.
