Simann
- Jonathan
- May 11, 2019
- Murfreesboro, TN
- 2019 Rubicon Unlimited
Used but in great condition, bought them off another member here but never used them myself. Not missing anything. Installation instructions are online, you will need some blue loctite. Retail for $240.00 a set of 4!
$150 shipped inside USA.
Paypal/Venmo accepted. Local pickup also just fine!
These 5 on 5", 6061T6 aluminum spacers are an easy way of spacing out front and rear Jeep Wrangler JL & 11-18 Jeep Grand Cherokee axles by 1 3/4", allowing for larger more aggressive tires. Each kit comes with 2 wheel spacers, 10 standard wheel studs (pre-installed), 10 lug nuts. Wheel spacers are anodized in dark blue, using a double anodizing process for twice the corrosion resistance. In addition, each wheel spacer is wheel and hub centric for a perfect fit.
Made in USA
Spacers allow for a more aggressive stance by pushing the wheels and tires away from the vehicle. Allowing you to run a larger tire on factory or aftermarket wheels.
Anodized Aluminum Double anodizing process gives twice the corrosion resistance for long lasting life.
Hub Centric Allows the wheel to disperse the vehicles weight on the ring of the spacer relieving access weight riding on the wheel studs
Made in USA
- Color: Blue
- Bolt Pattern: 5x5
- Shipping Weight: 9.6lb
- Shipping Dimensions: 8in x 8in x 5in (L x W x H)
