Torero
I like the telescopic one, it’s excellent for the purpose and very cheap.I keep a 16" breaker bar with the appropriate size socket that works with the Gorilla Lug Nut key in the JL at all times.
I have the socket attached to the breaker bar and the tool is placed in a 18" long piece of gray, foam pipe insulation. I keep this affair, in the small compartment where the scissor jack is. Fits right in on top. With the foam pipe insulation, I have no metal to metal related rattles.
I learned long ago, you can be up chitt creek so to speak, sometimes trying to break lugs loose with the little tire iron that comes with the Jeep.
Once you see someone standing on a tire iron trying to break a lug loose and the lug snaps off, etc., you realize wise man/gal carries a breaker bar with socket as I do in the vehicle at all times.
I never personally use or allow use of power tools on my lug nuts.
EPAuto Telescoping Lug Wrench, Wheel Wrench with CR-V Sockets (17/19, 21/22mm) https://www.amazon.com/dp/B071FV7XVM/ref=cm_sw_r_cp_api_i_c8YbFb13T5S23
At home I use the impact wrench to loosen nuts, never to tight.
