Spare Tire
2JeepsJL&LJ
Chino Ca
2019 Jeep Rubicon Unlimited JL, 2005 Jeep LJ
Hello,
Those overlanders with trailers do you carry a spare for your trailer. I am going to install a Timbren suspension but it’s a 6 lug set up. Thanks
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
I’m building an off-road teardrop trailer and also using the Timbren suspension with 6 bolt wheels. I have load range E tires going on it and will probably not run a spare since the trailer will be under 2,000 lbs loaded so well under the tires rated weight limits.
Av8Chuck
Chuck
Thousand Oaks, California
2020 Rubicon
You can change the spindle to be whatever you need. I believe they have the Jeep 5X5. I run 35’s on the Jeep and the trailer but the trailer has 15” wheels which means I can run the Jeep spare on the trailer but I can’t use a trailer wheel on the Jeep.
Jeep Wrangler JL Spare Tire E598F30B-5C0C-413D-B1B6-4CF9C07B0D97
Ratbert
COS region, CO
AEV JL370 JLURD , AMG GLC43
Software Engineer
I'm fairly sure that that's only possible on their smallest (2,000lb) axle-less suspension. They're pretty adamant about not attempting that with their bigger (3,500+lb) suspensions.
2JeepsJL&LJ
2JeepsJL&LJ
Chino Ca
I am more concerned about breaking a spindle than blowing out a tire. Just trying to be prepared.
Av8Chuck
Chuck
2020 Rubicon
I guess. I have 5 on 5 on my 3500# axel and I can't imagine breaking the spindle on a 10 ft trailer. I considered going with the Timbren 2000 pound setup, I doubt I would exceed that weight unless I put an 1800 pound horse in it, but putting the same lug pattern on the trailer as the tow vehicle makes a lot of sense. There are a ton of 5 on 5 and 5 on 4.5 toy haulers that must have a GVW of at least 6000 pounds. I guess you either have to carry an additional spare or find a different manufacturer who can provide the lug pattern you need. I just don't have the space for another spare.
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
Another option is to carry a wheel adaptor from 6 bolt to the 5 on 5 Jeep pattern.
2JeepsJL&LJ
2JeepsJL&LJ
Chino Ca
Thank you all the idea’s. I am running 37” on the JL and the trail has fenders on it. I use Jeep for overlanding nothing hardcore. I will gamble for a while and see what happens.
