Spare tire blocks hitch ball coupler
Kleiss1
Gary
Arizona
2021 JLURD 2018 Mustang GT 6-sp.
How far are you towing your boat? It looks like your tongue level at 19”:with the 2” drop.
RDiddy
RDiddy
Rob
Ottawa
2021 manual Sahara
If you just need space above to drop the hitch onto the ball just open the door when you put the trailer on.
the winch post of the boat trailer sits not far from the face of the spare tire - you unfortunately can't open the tailgate very much at all.
Camaroboi13
Justin
San Bernardino, CA
87 XJ Pioneer, 2017 WK2, 2018 JLU, 2022 JTOD
Thanks for the link sir. Do you think that product would buy me the clearance necessary to get the trailer coupler under the tire to drop onto the ball? The pictures don't seem to show a lot of space after the relocation plate is on... but then again those tires are 35's and beyond, mine are only 33's
Jeep Wrangler JL Spare tire blocks hitch ball coupler 73544456071__5ECC6D8D-2F92-4BC8-9D7A-31036B28CE1F.fullsizerender
keep in mind, I’m on 37” tires, so 4” taller than your tires. You can subtract 2” from my measurements and go from there. I have 7.5” from tongue to tire bottom. In this configuration you would have 9.5” from tongue to tire bottom. Your tongue is flipped and that costs you 3” by looking at the pictures. That leaves you with 6.5” between tongue and tire bottom if you had this bracket with a 33” tire. 6.5” should be plenty of room to put your trailer on. Hope this helps.
Deathmatrix
Kevin
Kansas
2022 JL Rubicon, 2023 JLU Rubicon (wife’s)
We have used a hitch extender to pull our little Bushwhacker trailer. We have roughly 1200 miles of towing with it so far. No issues. Have taken it on some semi maintained forest roads.
Jeep Wrangler JL Spare tire blocks hitch ball coupler IMG_0291
RDiddy
RDiddy
Rob
Ottawa
2021 manual Sahara
It's amazing to me that the relocation bracket buys you that much height lift on your spare, even with a 37" tire. Take a look at the distance between the bottom of the rear bumper and the bottom of your spare tire. and then take a look at mine. I may have 1/2 to 3/4 of an inch between the two surfaces. That relocation kit lifts the spare only 2 inches total?
If these numbers are legit, yes, this does help immensely. This to me seems like the easiest and least annoying solution.
Thank you very much, I appreciate your first hand insight
Jeep Wrangler JL Spare tire blocks hitch ball coupler 38f227b9-a33a-465c-ac55-26b6d807c876
RDiddy
RDiddy
Rob
Ottawa
2021 manual Sahara
Nice camping set up man. Love your site. Do you have an idea of the gross weight of your camper?
2nd 392
Ca
The steel ones weigh ~ 13-15lbs, Teraflex aluminum relocation brackets are featherweight and come with a tire bumper extension kit. ~$135-150. Up 2” out 1 3/8” as I Recall. The heavy RC steel one that would have put it in the reinforcement needed weight range is in the garage with other unused parts I wasted money on.
Jeep Wrangler JL Spare tire blocks hitch ball coupler FDF18B1C-D642-45FE-A8F6-8B95ACFD8713
distance from the receiver with 35’s
Jeep Wrangler JL Spare tire blocks hitch ball coupler AD55046C-BE5F-42C1-A8E3-C55ACAA25C37
Kleiss1
Gary
Arizona
The other picture shows 19” to the top of the ball.
Mocopo
Kevin
Arizona
22 JLURXR
Looks like you may have already settled on the solution being a spare relocation. I just want to add one more reason to do that over the extender: by using an extension for the hitch, you are adding a lot of extra stress to the hitch. Your jeep is only rated for a tongue weight of 350 lbs from factory (maybe slightly more depending on engine and other options) and i bet your going to already be maxing that out with a 3200lb boat.
BetOnBlack
Princeton, TX
2019 Rubicon Unlimited
Supreme Leader of IT
So I have a question. You say the boat is 3200lbs. The unlimited is rated for max towing of 3500lbs. Does your weight include fluids, gear, the trailer? If not you are going to be way over weight.
Carolina Jeeper
Rollie
North Carolina
It's an excuse to lift your Jeep and use a drop hitch.
Maybe install a tire hanger on the boat trailer and carry the spare on it?
Apexcars
North Texas
2020 RAM 1500
From what the boat dealer sent you, it looks to me like you are going to be at 19” to the top of the ball with the trailer level.
I also agree that if you boat weighs that much you are goin to be way over the towing weight limit for a Jeep. You will probably also be over the tongue weight limit and if you have people or gear in your Jeep you will probably also be over the payload limit on the Jeep. Will it still pull it? Sure. Will it safely handle in an emergency situation or if it is wet or windy? Very doubtful
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
I really, really hesitate to remove the spare tire. Seems like a kick in the nuts waiting to happen, so that's worst case scenario.
Reevaluating the hitch extenders as we speak. Thanks for stopping in with your insight. Much appreciated
I towed our small camper for approximately 54,000 miles with a hitch extender. Just saying. That is on road and off road.
Jeep Wrangler JL Spare tire blocks hitch ball coupler 1713783695541-2o
I cut my hitch extension as short as possible to give the ball the clearance I wanted with out the extra length that I did not need.
Deathmatrix
Kevin
Kansas
Dry weight if I remember correctly is around 1700, with gear we are probably around 2200 or so.
