Sanchese
- Carlos
- Feb 14, 2021
- Toronto, Canada
- 2021Rubicon, 2022 Rubicon Xtreme Recon on Order
Do they ship to Canada?
I dig your grills what are they from ? I just ordered the alpine S-S65C and they don't come with grills.
I think you'll find that you get better volume out of them as well I paired them with Terra Acoustics Front speakers. I no longer have my Jeep as I started having Electrical issues with it. I ended up upgraded the speakers in my truck to the same ones.Thanks to this thread the install went clean. A few notes... As previously mentioned the wires for the tweeter connections were reversed, so I was careful to check that. There's also a coil on the speakers that doesn't quite fit right no matter how I rotated the speakers, I'm pretty sure post installation it's been pulled from the mounting tape on the speaker and is "unmounted" but still connected. I picked up 8- 8x1" and 8- 8x1/2" machine screws to mount the speakers and grills from ace, the hardware with the speakers and pods was a bit long. Full install took about an hour. I pretapped the screws for the speakers after dry fitting them in the mounted pods then pulling the pods down. It seemed easier to get them fitted correctly this way.
The sound is way better altho the tweeters are a little tinny, I'll see if I can pull a little out with the equalizer. Nice bass and punch with these speakers.
I must say I was always pretty impressed with the premium alpine system until I started upgrading and then I couldn’t stop. HahaI have done so much reading and searching my eyes are bleeding. I still haven't found a definitive answer.
I have a 2021 with Alpine premium, I want to upgrade the soundbar speakers still using the stock Amp and wiring . I bought some
DB+ Series 6-1/2" 2-way car speakers, for my other jeep before I traded it in.
My question is can I use these speakers in the sound bar of the Alpine premium system and have them sound right or do I have to get component speakers? I am overwhelmed with searching for component speakers and trying to figure out what will work if I have to get separate crossovers ect..
My current speakers I have on hand.
- handles up to 100 watts RMS (300 watts peak power)
- frequency range: 40-22,000 Hz
- sensitivity: 92 dB
- 4 ohms
