No not at all, basically slid the bracket with the bolts welded to it behind the factory bracket, held with one hand and started the two nuts. Then tightened down. I used the middle position so one was behind the pedal but no big deal.So the More DP wasn’t that big a deal?
can u please post link where you purchased?No not at all, basically slid the bracket with the bolts welded to it behind the factory bracket, held with one hand and started the two nuts. Then tightened down. I used the middle position so one was behind the pedal but no big deal.
Just finished adding the MORE dead pedal, a 13" antenna, and sill protectors!
Pretty easy installs all 3 took about 30-45 minutes.
How is the reception with the antenna? Which one did you get?
It makes for a good left footed bass drum pedal!I don't understand why people install a fake third pedal when they could have ordered a manual transmission to begin with![]()
