SOLVED! OFF TOPIC - Any HVAC Furnace experts here?? I need help!!
Beachcomber72
2022 JLU High Tide
I got it!!!
Remove the furnace and bring it with you out to a trail we’ll all meet at and we will definitely get it solved there. I’ve never seen jeepers on a trail not solve a problem.
Beachcomber72
2022 JLU High Tide
By chance is there any oxidation or debri on the flame sensor itself or corrosion on the electrical connector going to the flame sensor? Just to rule it out clean both parts really well by scraping a clean bare surface on each.
Caliguy
Caliguy
Norcal
2022 Rubicon JLU
Ok, so at this point it literally has to be one of two things
either new pcb control board
or
clog in the exhaust.
So far we have
new thermostat
New flame sensor
New gas valve
New capacitor
New air filter
when jumping R and W - inducer turns on and works as intended
when jumping R and G fan turns on and works as intended
when turning in heat mode on thermostat, furnace works as intended for about a minute then surges on fan without turning anything else on
working theories:
1. exhaust is clogged and pcb is telling furnace not to turn on coils/gas
- this begs the question, why does it work for the first cycle when turning on heat mode for a minute
2. Bad pcb not triggering the right components
- this begs the question, why does fan and inducer work when jumping the wires
Caliguy
Caliguy
Norcal
2022 Rubicon JLU
iv replaced it, I have also sanded from 1000, 1500, and 2000 grit and polished it
Beachcomber72
2022 JLU High Tide
How many wires are coming out of wall to the thermostat and what colors are they and what model of thermostat are you using?
Caliguy
Caliguy
Norcal
2022 Rubicon JLU
This doesn’t seem applicable, it has an electric coil that glows, the gas is then released and ignites.
The problem is when the fan surges, nothing else turns on, not the IGNITER, nor inducer or has valve.
however, when turning in heat mode for that first cycle, it all works flawlessly for a minute.. inducer kicks on, igniter glows orange, gas valve turns on and we got blue flames, then tan comes on.
bad part is after, fan turns off, then fan relay and fan surge on and off over and over again. Sometimes 11 times on and off then tan is on for about 30 seconds, then 13 times then in for 30 seconds, then 14 time
Double check the leads going to the gas valve too.
tech installed it. There are two leads to it, a yellow and green, and a blue. I don’t know if it’s correct or how to check if they’re plugged in the correct slot. To be honest, I’ve tried switching them and there was no difference
Caliguy
Caliguy
Norcal
2022 Rubicon JLU
I just got the Sensei touch from Home Depot. The wall has a red, white, yellow, green, blue
red wire to RC on thermostat
White to W
Yellow to Y
Green to G
Blue to C
it’s the same on the pcb
shouldn’t be an issue as nothing was changed here when it stopped working correctly
Beachcomber72
2022 JLU High Tide
Man I’m truly at a loss on this one. I’m sorry brother. Other than the possibility of blockage in the exhaust line I have no other ideas. I’ll watch the videos you posted earlier again to see if I’ve missed anything. BRB.
I’m truly praying for you.
