thanks, the pressure switch test in the video just tell me real quick if it’s a bad pressure switch or a clog so I’ll know tonight if it’s related to exhaust/intake.I've had similar happen on two occasions, once when we first moved into our then new house and then again when we replaced the furnace.
The first time the issue was intermittent, and nobody could figure out what was happening. After having different techs look at it each time it failed, I was at a loss. then one night when it wouldn't fire I started to just do what I shouldn't and just tried different things. At one point I pulled the intake plumbing out from where it entered into the furnace. There sat a nice big maple leaf. The reason the issue was intermittent was that the leaf had split in two down the spine Sometimes the two pieces would fall on top of one another allowing enough airflow. Other times the two halves would sit side by side completely blocking the inlet. Removing the leaf fixed the issue.
The second time with the new furnace the issue was caused by bad install of the exhaust pipe. There was a low spot in the pipe causing condensation to sit in the low area blocking the exiting airflow rather than draining back and being captured by the condensate system. This one became obvious when we started getting water in the pressure switch.
I doubt your issue is with condensation, but I would lean toward some blockage on the intake side. I agree with the suggestion that someone made of disconnecting the intake at the furnace to see if it fixes the issue. If you can get your hands on a plumbing snake I would run that out the intake and exhaust from the inside out to see if you can clear a blockage.
Good Luck
lol thanks. I find most jeepers to be DIY’ers or folk who aren’t afraid to get their hands dirty from all walks of life. Between the Jeep brain trust, and a gun forum brain trust Iv also cross posted, I’ll get this sorted out, even if I have to use my Jeep to haul it to the shooting range for all those who helped to take a few shots at it.Where on the Jeep is this located exactly?
In all seriousness, if your doing these types of diagnostics on your furnace with guidance from a Jeep forum then you may want to take pause. Carbon monoxide poisoning is no joke. I appreciate the can do attitude of the do it yourselfer, but a healthy respect for things that can kill you and your family is likely in order.
On second thought, did you check to see if all the fuses are seated?![]()
Mine is 1/2" PVC pipe coming out of the bottom of the furnace leading to the outside of the house.what does the drain line look like so I can check?
I just ordered a new board that will be here Amazon on Wednesday. If that doesn’t fix it, Itl have to be a physical obstruction somewhere like the drain, exhaust, or ductwork.
At that point, new board, new gas valve, new flame sensor, new capacitor, new thermostat, cleaned burners, new air filter…. The damn thing only needs a new inducer blower and new fan to be a completely new unit. But I have jumpered those and they both work
no not yet
We have a Coleman furnace that did the same thing. I unplugged one of the vacuum lines that went from the vacuum pressure switch to the upper burner box. Solved my problem.
It’s located in the back seat seatbelt crevice directly behind the front passenger seat between the right there and hmm over here maybe and yet directly above the oh here it is section.Where on the Jeep is this located exactly?
