AgileHumor
For inverters greater than 500w, using the factory Auxiliary (Aux) Switches is not possible due to the 40amp limit on switch #1 & #2 (and 15amp on #3 & #4).
This normally requires a high powered 300A relay for my 2000watt inverter controlling the power which was not desirable. I simply wanted a inverter that had the ability to be switched on by a low amp control wire available from my JL's Aux switches..
After exhaustive search, I found a inverter from Go Power GP-ISW (700-4000 watt models) that allows control via single positive output from the Aux switches. This allowed me to take the Orange wire from my JL’s Aux Switch #3 and wire it to terminal #4 on the Go Power GP-ISW inverter.
For power, I ran 2/0 thick copper wire directly to the JL 12v battery. The switching is done via the Aux Switch settings in Uconnect to set it to turn on at ignition only.
So happy I found one vendor (at least that I could find) that provides a simple control mechanism for the inverter. Hope this helps you all!
The very rare documentation on this remote control terminal wiring is located here on page #33 (also uploaded an image of the terminal wiring and manual, since later revisions of manual leave the terminal wiring documentation out):
https://s3-us-west-2.amazonaws.com/catsy.549/78158_MAN_ISW.pdf
Go Power 2000 watt Inverter I purchased:
https://www.amazon.com/Go-Power-GP-ISW2000-12-Industrial-Inverter/dp/B07D4XQ8P3
