Tennessee SOLD!!! LSD narrow rear axle complete with brakes
Crawdad1028
Robert
Knoxville TN
2018 JLU Sport 6 speed with rubi axles, lockers, RCVs, trusses, and 5.13s
Crawdad1028
Crawdad1028
Robert
Knoxville TN
Still available.
Crawdad1028
Crawdad1028
Robert
Knoxville TN
Do you still have this and what is your absolute bottom dollar?
Sorry man I just sold it a couple days ago. Updating the post now.
mgroeger
Hurricane, UT
2021 JLUR 2.0T, 1991 YJ rock crawler
Insurance ponied up $3900 and the dealer charged me $4700, new, in crate, delivered to dealership, including taxes and 2 year warranty.
Maverick909
Inland Empire
www.instagram.com
was that with all the brake rotors and axle shafts? @mgroeger
mgroeger
Hurricane, UT
Both front and rear were complete factory axles with 4.10 gears and lockers delivered in Dana/Mopar crates, the only thing that needed to be put in them was the gear oil.
Turns out the rear axle comes with rotors and fully loaded calipers but the front doesn't.
Maverick909
Inland Empire
www.instagram.com
awesome!! thanks for the reply. this is the route i will be taking my self. cant wait to get the extra cash to order them up!
mgroeger
Hurricane, UT
Nice!! You will also need the following...
(2) Mopar wire harnesses to wire the lockers in. They are $75 each.
(1) Mopar AUX switch bank. $299. You need a switch to control the lockers, we tried everything/everywhere and those dashboards are so packed behind the front plastic that there is no place to put a switch. We were not the only ones to discover this, another guy bought the switch pack as well.
(1) Tazer, can go with a Tazer lite if you'd like for $220. You need this to tell the computer your are running 4.10 gears and what size tire you are running. You can get away with switching tires and not telling the computer and only your speedo will be off but you MUST tell it what gears you are running.
(1) Trip to the dealer for around $100 for them to flash the computer to tell it you have the AUX switches. These switches are defined using the factory radio for you to tell the switch how to perform.
(1) Alignment, around $80
(3) Qts fluid to fill the diffs, around $30
Wiring in the AUX switch is a bit of a pain according to my friend who did it.
So on top of the cost of the axles you need to factor in another $900 unless you already have some of the above.
Maverick909
Inland Empire
www.instagram.com
Great break down.! i will be running the lockers off a S-pod relay system. still working out the details on that though. might not let me but that is ok too. ive already got it in mind to add the aux system if need be. thanks again! anything is better than the limited slip clutch pack failing and blowing out the rear axle seals!
mgroeger
Hurricane, UT
The S-Pod should work fine. We had open diffs so never experienced the LSD, that would suck failing teh way you state. We are headed back to Moab 12/30 for two weeks... this time with lockers :)
