bigalex
We've had to sell our JL as doing a US roadtrip for the next year and have some key upgrades we removed prior to sale. I want to offer up for sale!
Following this link (https://www.jlwranglerforums.com/forum/threads/aftermarket-stereo-installed-finally.46065/) - I went all in and bought the JVC headunit and it has worked great.
I removed the system last night (headunit with wiring harness, mounting plate, plastic surround, microphone) and it is in the original box. I wired up all the harness fittings from Crutchfield so it should just plug and play into a JL with Uconnect as mentioned in the above link.
Note our backup camera did not work with this unit, but the improvement in sound without any changes to the speakers was HUGE. Not to mention Android auto / Apple carplay (via USB), actually responsive touch screen and bluetooth that autoconnects!
Comes with bus connector to monitor JL engine characteristics, antenna adapter, iDatalink Maestro interface module and Factory integration adapter, and 3 Bojo Trim Panel tools and removal of legacy system and installation of this one instructions.
Note I have connected the wiring harness and adapters already as we use it in our 2018 JL. Therefore you should just need to plug and play once you got the Uconnect out. Only fiddly part is the CANBUS connection behind the glovebox.
Total cost for me when I bought this 1 year ago = $619.36.
JVC KW-M750BT unit = $349.99
iDatalink Maestro RR Interface Module = $121.68
Hardness, tools, other pieces = $147.69
Offering for $200 for the lot.
Postage extra (depending on how quick you want it and how far from MA you are). Probably be around $25.
I'll post some photos when I get back from work tonight. 1 year old so not a scratch on it.
Let me know if you have any questions.
Al
Al
