Soft top rattle
Mikejd1
Wrangler JL
I am on travel for a couple of days with no access to the Jeep. Perhaps someone can look at the little wheels in the track and see if they are screwed on or permanently mounted to the black bracket. We need to source slightly softer wheels that are a little wider and taller so the roll in the track without all the clanging.
My tape is still holding up and things are quiet, but I realized this was a temp solution to test the theory.
Just checked, wheels do not come off... I wonder if this will work, if you wrap it around the wheel
https://sugru.com/
mlebofsky
Denver, CO
2019 JL Rubicon softtop
Director, DoD
https://sugru.com/
If it hardens "hard", then we haven't fixed much except for taking up some free space in the track. We need something that remains rubbery so it doesn't make a bunch of noise in the track.
Mikejd1
Wrangler JL
oooo, good point, back to the drawing board
mlebofsky
Denver, CO
Director, DoD
Sugru DOES harden “rubbery”.
Hmmmm. You would still need to keep the wheels very round so they would roll easily in the tracks … That's why I was considering a spray on rubber coating that would dry fairly quickly ….
Mikejd1
Wrangler JL
I bought some yesterday. The hell with it I’m gonna give it a shot. Apparently it’s pretty easy to remove it too
mlebofsky
Denver, CO
Director, DoD
Good luck and let us know !!!!
Mikejd1
Wrangler JL
I’m just reporting back in about 1 1/2 days into it and it’s flawless. Best thing I’ve done. I didn’t get the rubber to be super circular but it flows in the track perfectly.
now. I need to conquer the other rattles from those plastic track pieces that sit on the Jeep frame. Fall is here now in New England and only a few more weeks left with the soft top anyway. I’ll fix those rattles next spring with the same Sugru
mlebofsky
Denver, CO
Director, DoD
Does it harden all the way or does it stay a little rubbery? Did you do the sides of the wheels also?
Mikejd1
Wrangler JL
A little less than 24 hours it was still a bit rubbery. I haven’t checked since last night. In a few hours I’ll check to see if it full hardened. I got enough on the wheel to do the sides as well
OldGuyNewJeep
Don
CT
Try this?
Jeep Wrangler JL Soft top rattle upload_2019-9-22_10-15-0
Mikejd1
Wrangler JL
Well checking back in after about four days. Unfortunately it did not work. Rolling the soft top up and down quite a few times caused the rubber to break apart on the wheels. Back to the electrical tape
mlebofsky
Denver, CO
Director, DoD
Good to know. Thanks
