Soft top help
rocketman9132
Don
new brunswick
2020 jeep JL Rubicon
Hello. Just received my new JL Rubicon and put the soft top on today. We double checked all the instructions and think we did it right. There is a gap between the top and the front windshield of approximately 3". Can this be adjusted? What am I missing?
Rico1111
Rico
RI
2018 Rubicon 2 door JL
You have to let it stretch out!!!!!!!!! There are a million posts on this. To let it sit in the sun . You can try to pull it to get the j hook to catch then latch. You wont be able to open until it is stretched out. Day in the sun usually does it!
rocketman9132
Don
new brunswick
Rico1111
Rico
RI
There has never been one wrangler that the brand new top just went on and there was no need to stretch. I myself was able to strong arm mine when I installed it but then could not get it open again till the next day after leaving it in the hot sun for the day.
rubileon
Water over dirt planet
JLUR RHD 3.6
The op says there's a 3" gap... that's never normal.
2mnycars
Canada
JLUR
New Brunswick is a beautiful province. Incredible scenery.
I don't know what the weather was like today; however, about sunrise here in Toronto Ontario it was about 9 degrees Celsius. 48 F degrees.
BlackGenesis
Andrey
Muskegon Michigan.
18 Sahara unlimited
Had the same issue 2 weeks ago. Put on the top and did not verify if it closes. Took Jeep right away to a gathering, just to realize that I can't close soft top when I tried to cover it up. Looked like good 2" gap, at least.
After it sat in the sun for one hour, I pushed at each cros bar starting from the back forward and was able to latch it.
rocketman9132
Don
new brunswick
