Redbaron73
We spend 3 months in Montana each year, and typically tow our Duramax 2500 crew cab pickup behind our motor home. When ordering the jeep, I had my summer usage in mind, so I ordered MY*JLUR with the dual top group. The hard top stayed behind when we left for Montana.
It has been so nice to run the top in its fully open mode, and many days I can leave it without closing it up.
I also have installed the diabolical slipstream. This combination is perfect for running around town, not worrying about valuables being stolen.
The only issue I have had is removing the rear window bottom bar. It is not that hard when the diabolical is opened, but when it is closed, getting a grip on the bar to pop it out is more than challenging.
I recently discovered a trick, after over 100 times of struggling with the darn thing. It is much easier to pop out the passenger side before the drivers side.
What I found that works best is to first pop out the corners and release the seal of the passenger side, then open tailgate, release seals on driver side, then finally slide the lower bar all the way to drivers side and pop out the passenger side if the bar. This process is now down to about 20 seconds compared to my 60- 90 second struggles I was having.
Hope this helps someone else.
