Soft top at high speed
Lousab1
Louis
New York
2020 Jeep Wrangler
I made the mistake of listening to a friend with the same type Jeep but a year older, a took it on the highway (with speeds in excess of what I should have been doing). I have done this at least 4 times but the last one ripped the soft top from all three cross bars! Wondering if anyone has repair suggestions, or do I need to replace? Also does Jeep (or other companies) make a cover that can prevent air from pushing into the folds when traveling. BTW back window was out and sides were still on so the soft top wasn’t all the way down. Thoughts?
Heimkehr
Pennsylvania
2021 JLU 2.0T
If the fabric that separated from the cross bars is still intact, you might consider reattaching them to the bars with a well-rated fabric glue. Used properly, it provides excellent adhesion.
Failing that, and depending on the degree of damage, you might be in for the cost of a replacement top. Photos would provide necessary context here.
Htfan
Orange County, CA
2018 JLU Sport S - 3.6L
I'm trying to understand exactly how this happened. I drive at freeway speeds with my softop in various positions and haven't dealt with this. As mentioned above, pictures would help.
Only-In-A-Jeep
North Georgia Mountains
2021 Jeep Wrangler Sport
Is this the factory soft top you are referring to or did you replace that with an aftermarket frameless top? Factory soft tops don't simply come apart at highway speeds. There has to be more to this story.
Htfan
Orange County, CA
That is what I was thinking. My softop is not mopar/BestTop and is made by Mastertop with no problems at high speed.
X35
PA
2025 Wrangler Willys XR
OP, don’t just dump your question here without answering the follow up questions. We want to know just what the hell happened to your soft top. Some pics of the carnage are also required.
MichaelT333
Delaware
2022 Willys
I have an oem hard top for winter and a bespoke soft top for summer. I have do 85mph regularly on the highway with the soft top and have never had any issues. I have had the soft top for almost 4 years now. No tips or tears
mixdup
Atlanta
2024 Unlimited Rubicon
Something isn't adding up here. If you were driving fast enough to rip the soft top on a Jeep, you probably should be in jail
I regularly hit 80 and the soft top of my JL doesn't make a sound and doesn't flap or wiggle at all, unless I'm next to a truck with the wind coming off it
to actually come off the supports either it was already damaged or you were going faster than a Wrangler ever has
  • Like
Reactions: Guv
yokramer
Snark Incarnate
Gonna need some pictures here of what when wrong
73TAWM
Troy
Missouri
21 JLU RUBICON 2.0T 3"LIFT 37's
Lumber Sales
I installed the Besttop Trektop Ultra, with slant back. 80+ mph on interstate, fully opened (mine doesn't lay down all the way because I have a 4" top extension on my Diabolical cargo) with windows out (only way it will fold all the way open) and no issues. I have thought it would catch too much wind but it doesn't seem to mind. Been driving that way for two years now as I am too lazy to remove and go back to hardtop each season. But I don't mind the noise or cold in the winter, with the heat on it's not that bad. Maybe you have a cheaper aftermarket on there?
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
It's a top not a drag chute, what the hell were you doing to cause damage?
6th Floor Mule
Keith
Woodstock, GA
2018 JLU Sahara 6MT
Guessing it’s sailcloth and not twill? Buddy of mine had the same issue with his ‘19 Sport.
flyer92
Nevada
I don't understand. Was OP driving at Mach 3?
  • Like
Reactions: Guv
