wibornz
- Ted
- Aug 3, 2018
- lansing, Mi.
- Website
- www.instagram.com
- JL Unlimited Rubicon
- Occupation
- Retired from Corrections....I have stories.
I have been running bead lock wheels for the past 53,000 miles. This post is a run down of the time and cost to swap new tires on my bead lock wheels. Note, this is with me and a bud doing the lion share of the work.
I just installed new tires on my bead lock wheels. So It took me two days. first day, put the Jeep on jack stands, pulled all five tires off the Jeep. Then took all the bead lock rings off. They have been on for 53,000 miles. I did have a broken bolt prior to the removal of the rings. In the process of removing the rings, seven more bolts broke. I thought fuck this is going to be a pain in the ass. Nope, I was able to thread them out through the back of the wheel by hand. Luck was on my side. Take the wheels and tires to a local tire shop as they will break the inside bead, remove the tire and put the wheel back into the new tire for $5 a tire. I ended up waiting 2 1/2 hours for this to happen.
Get back home and get two tires mounted and the bead lock ring installed and torqued down correctly. The next day, started a little tough. I finish mounting a tire and torquing the first bead lock ring down and fuck, I forgot to throw the bag of balancing beads inside the tire. Obviously I needed more coffee before I started the day. Remove the bead lock ring pull the tire off the outside bead and toss a bag of balancing beads in the tire. Re-mount the tire and re-install the bead lock ring. Then repeat on the two remains wheels.
So for those wanting bead lock wheels, here is a little break down of the cost and time when doing a bead lock wheel and tire dismount and mounting new tires back to the beak lock wheels.
Will cover cost first.
You should alway replace the bolts with new bolts for the bead lock ring when mounting new tires again. The bolts get fatigued over time and take one heck of a beating.
Cost of 120 new Stainless Steel bots. $86.97.
Sure I could have bought them a little cheaper on line, but wanted to ensure that I got American made bolts, not some cheap low quality china bolts. The bead lock bolts are not something to skimp on.
$25 to break the tires down. I will gladly spend that money every time. I can and have manually broke down 37 in tires. It is a pain in the ass and I would gladly spend $10 a tire to get it done so that I don't have to do it.
$50 for the bags of balancing beads.
kind a Total cost $161.87 for me to mount them myself and do it right.
I did not include fuel to chase supplies down, the cost of shop rags, a can of PB blaster, anti seize and buying my bud's breakfast on the second day....... I am assuming if you plan to do this you already have the couple hundred dollars worth of tools to get the job done... or $7 worth of tools from harbor Freight..... lol.
Time.
1 1/2 hours to go get the new bolts,
1 hour to jack the Jeep up and put it on Jack stands and remove all five tires.
1 hour to remove the rings and get the broken bolts out of the wheels
3 /12 hours to take the tires to the tire shop and get them broke down and get back home.
6 hours to mount and install the bead lock rings on the wheels and air the tires back up to 28 psi this time also includes cleaning the bead lock ring mating surface where the tire contacts the bead lock ring. That was a shitty nasty dirty dusty job.
1 hour to put all the tires back on the Jeep and take the Jeep of the jack stands.
1 hour to put all the tools and stuff away.
Total approximate time. 15 hours. With two of us working on the project.
VS a non bead lock 5 tire change up.
Spend an hour at the tire shop or so and $50 to get the tires dismounted, mounted and balanced and installed.
I love bead lock wheels, I use them and full understand the commitment to having them. Just know the cost of the wheel is just the beginning.
This is what my bead lock rings look like all five of them are similar in condition. I think I would have destroyed a normal wheel. My ATX slabs have been down right tough.
This is what the mating surface of the bead lock ring looked like that contact with the tire. I wire brushed these back to a clean surface.
The rings are just tough. Mind you not all bead lock rings are created equal. If you buy some of the cheaper wheels and wheel hard, you may have to replace the ring also.
All five rings look similar. The Rubicon Trail, Moab, Windrock and Rausch Creek were hard on the rings.
With that said, just know that the tires have been through hell also. These rings got like this with Cooper STT PRO tires mounted on them. That mean that the tire withstood the rocks that caused the gouges in the rings before getting to the bead lock ring. In 53,000 miles with many miles off road, the Cooper tires have performed awesome. Zero flats, zero punctures, zero air loss, zero balancing issues and the tires did not cup or wear in any odd way. I think I could have gotten another 10,000 miles out of the tires, but I am running out of time to get things done before up coming trips. So they were pulled off. I will put the tire up for sale on FB and think I can sell them pretty easy and there is still plenty of tread, but I do not what to go through all the work to change out tires while out traveling.
Most shops will not mount bead lock wheels. The ones that do, charge appropriately for the work. We have a local off road shop and they charge $125 an hour to mount bead lock wheels. I would hate to image what it would have cost if I had to have the 7 broken bolts extracted from the wheels. Granted they would have been a little faster than me as they have a lift and tire machines, but still expect to spend at least $500 or so to get them done right.
On my Jeep:
Time.
On my Jeep:
