So this broke, window defroster hook up?
JAY1941
Jay
Massachusetts
2020 JLUR
LE
I just noticed this is broke. Does anyone know how it’s connected?
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Jeep Wrangler JL So this broke, window defroster hook up? 53F82E76-9CEF-44F1-BBFD-CD29F395B638
Some form of soldering is used to attach it. This has been a common problem, and full glass replacement seems to be the dealers go-to.
Coyne11
Steven
Charlestown, IN
2018 Jeep JLU Rubicon , 1989 Toyota Pickup 4x4 SAS Swap
Mine broke loose as well. I took it into the dealer and they said the first attempt they have to try and resolder it back on and if it comes loose again, they get a replacement back glass. I’m unfortunately into the second attempt but have not taken it back in yet. Mine will all be covered by warranty
jludave
The Isle of Long
IT Manager
This has been an issue even back with the JK model. If you don't want to deal with the dealer you can try fixing it yourself using something from https://frostfighter.com/
However, if you are still covered by your warranty the dealer option is your best bet.
JeepCares
Auburn Hills, MI
JL
Hey, JAY1941 and Coyne11. If you need any assistance working with your dealer for repairs to this component, don't hesitate to contact us in private message!
Kate
Jeep Cares
Gazorpazorpfield
NJ
2020 JLUR Bikini Pearl, 2009 JKU X
Kate
Jeep Cares
Hi, same thing happened to my hardtop defroster, I will message you
JeepCares
Auburn Hills, MI
JL
WagzDad
Carroll
South Louisiana
The cause? The poor connection, with low effective contact area, makes enough heat to soften the solder.
Solutions:
1. Still in warranty? It’s a dealer issue.
2. out of warranty pop the tab out of the connector and reattach with frost fighter silver epoxy. It’s a slow set epoxy that requires additional heat to cure. Read and follow the directions. There’s a decent video on the frost fighter website. Once it’s cured, I’d let it set a couple days before moving on to reattach the connector. You can improve the connection by trimming a sliver of the rubber boot around the tab area, cutting 3 or 4 circles of uncoated foil (copper if you can find it) to go between the tab and connector To tighten it up. A little dab of conducting copper antiseize , like used on spark plugs, in the boot helps conductivity.
3. Best. Change the connector and tab to the improved clip design sold by frost fighter. It’s a better connection and moves the hot spot a little further from the epoxy joint.
F800
Canada
2020 JLU
Broke on mine too, but I went a full winter in canada without it and didn’t bother me. I get it, factory defect, still in warranty etc but i don’t view it as something worth my time going into the dealership for.
