So my hood was damaged. Fix?
balan
Brady
Pittsburgh
heraglobaltech.com
2019 Moab Punk'n
Engineer
Walked out to the garage where I park my Jeep while I'm at work. Noticed that somehow, my hood was damaged. There are two medium sized dents in the hood.
They are a little hard to see in the picture.
I have no idea how this could have happened. But, I am looking for recommendations on how to fix it. Thoughts? Thanks so much!
Jeep007
Andrew
Long Island, NY
JLUR
A PDR guy should easily be able to fix that for you. I’ve used them in the past they do great work. Comes out looking as good as new. Prices vary but probably around $150.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Looks like someone got a little too emotional on the Moab..
Dashcam with parking mode would have helped in this case..
This is why I have 3 cameras in the Jeep, locking gas caps, AND a hood lock soon, I get a lot of spiteful stares from neighbors when you driving around a Punk'n Jeep.. as they poke out of their beat up Corollas.
Dagwood
Alabama
2019 Jeep JL, 1999 Jeep xj, 2008 Scion XB, 2015 Scion XB, 1966 Ford F100, 1969 Oldsmobile
Sorry to hear but I think pdr would work as well since no crease in dent.
This happened to the hood on one of mine at work as well. I can't even imagine how that could happen. I only drive a 200k+ milage beater to work these days.
Arterius2
Jerry
Vancouver, BC
3 cameras? Front, rear and..... Inside? Are they weather proof? Do you leave them up when you're running topless/doorless?
Yes, You got it.
I only run with Sunrider for hardtop , so I don't have to worry about going completely topless, but shouldn't have any issue with going doorless though.
balan
balan
Brady
Pittsburgh
heraglobaltech.com
2019 Moab Punk'n
Engineer
Ag
Looks like it came from an impact.
My first guess would be to try a paintless dent repair place.
Agreed that it must have been an impact. One of the weird things is that the dent lines up almost perfectly with the solenoid installed near my battery. There is no evidence that the inner liner touched anything after the impact (no marks on it).
My dad used to have a dent puller, but I'm thinking I'd try a professional for this. Thanks for pointing out there are professionals!
sdynak
NJ
18 JLU Sahara
Agree with others.. those PDR guys can take care of that like it never happened. Sorry to hear about this. If you ever find out how it happened please do let us know. Hope it all works out in the end.
vavaroutsos
Pete
Scotts Valley, CA
Ag
A dent puller and PDR tools are totally different. The PDR guy will setup a reflection board and work the dent from behind with various push tools. He may use a glue puller if there is no access to the rear of the panel, but it's a last resort.
Pig-Pen
Eastvale, CA
2018 JLU
jabroni
Isnt the hood aluminum? If so, i dont think a PDR will work. It doesnt have the memory that steel has. That will take some pulling and body work i think
vavaroutsos
Pete
Scotts Valley, CA
You are correct that the hood is aluminum and aluminum doesn't have memory like steel. However, you can still use PDR. It just takes more time as the aluminum doesn't remember the shape it had. You have to push a bit harder and the aluminum doesn't stay quite where you pushed it.
Pig-Pen
Eastvale, CA
2018 JLU
jabroni
Thats along with what i was thinking. Ive had pdr done on my vehicles. Really neat how they can just tap it and it pops back.
I watched some show on tv where they showed the difference in body work on aluminum vs steel. An F150 had a minor dent in the bed and they were “hammering” it back and then it basically looked crumpled reynolds wrap. They said they would have to use bondo(?) to smooth it out. A lot more work to repair.
For the hood, i would think they could mostly pop it back but if you want it to look good, it will require some body work and repaint of the hood.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Screwing with someones parked vehicle is disgustingly petty. Hopefully, it can be squared away and looking like new again. I'd also highly suggest a quality dash cam. Not to be an alarmist, but ive seen and heard of repeat damage after the first was repaired.
