So... how do you hang your fire extinguisher???
goingsolo2
Long Island, NY
Teacher
Have the same one but when I took the hard top off and put the soft top on for summer this position will not work
Gotcha...good info. I have the one touch power top so it works great.
Nik H
Nik
RI
2018 Jeep Wrangler Rubicon JL
VictorChampion
Edmond, OK
2021 Rubicon Unlimited
Mine are just strapped around the roll bar while resting on the little notch plastic cover. I did put some loop portion of velcro on the bottom that sits on the plastic. No rattle or movement at all and quick detach.
Capt-Zoom
Capt-Zoom
North
2019 JL sport s, 4door. 1999 TJ Sport
I feel that I must remind you, Sir, that there may be children reading this forum.
They, like me, might be inappropriately inclined to giggle at the thought of a fire extinguisher condom.
They could be scarred for life! This is not a trivial matter.
Please be more discreet in the future.
Thank you.
If the word CONDOM scars you or your children you've got bigger problems than the word.
Bluebear
Bryan
Denver
2018 Wrangler JLU Rubicon Ocean Blue
I looked on the Element website and only the E50 is sold. Would you be willing to tell me where I could get an E100
I did buy it direct last year, I guess they changed it. The concern with the E50 is the diameter, might be too skinny for the maglight mount. Not sure where you could find the E100, maybe some other stores online will resell it?
Nik H
Nik
RI
Found it on eBay and thanks for answering
UUBob
NoVA
2020 JLUR; ‘95 Land Rover Defender 90
I was not familiar with the Element fire extinguishers until I read this thread. After a few minutes of research, I’m sold. Another very useful piece of knowledge I learned in the forum. Thank you all for sharing.
DKAwildcat
Don
Overland Park, KS
2018 Wrangler JLU Sahara, 2008 Chrysler Crossfire Roadster, & 2015 Acura RDX
M.O.R.E. bracket!
No drilling and comes with all hardware. Fits 1 and 2.5 lb bottles or anything 3 1/4 diameter.
CANNOT be used with soft top as it mounts in the same location as soft top mount.
RON
77RRAD: I’ve been contemplating getting a M.O.R.E. fire extinguisher bracket like yours. How secure is the fire extinguisher in the bracket? Is there a possibility that it could slip out of the bracket in a frontal accident, becoming a projectile? Do the bungee chords hold the fire extinguisher firm enough to keep it from rattling?
Mad Hatter
SW PA
2018 JLUR, 2011 MDX Advance
DKAwildcat, I've been meaning to express the same concern, but you took the lead. I really wonder about many of the fire extinguisher mounts in this thread--could they retain the extinguisher from becoming a missile in, say, a 50-mph frontal collision? The vehicle's air bags will prevent flesh from hitting the dashboard and steering wheel, but do nothing to protect from flying objects from behind.
Anyone mounting a fire extinguisher or heavy flashlight anywhere in the vehicle should consider worst-case retention, both the mount device TO the roll bar or other point, and the extinguisher or flashlight IN the mount device. Is retention as strong as a seat belt? Position high or low in the vehicle would likely also be important: High means could fly through the passenger compartment, low might be stopped by seats, etc.
I carry a fire extinguisher in both my vehicles, in the rear under-floor cubby. If I were to off-road where access from the driver's seat was required, that really leaves few mounting spot options: Footwell passenger (vertical or horizontal), footwell driver in front of the seat (horizontal), second row floor for reach-around. In all cases, the mounting system would need to be robust.
Regarding size of extinguisher, years ago I came across a small grass fire, probably caused by someone's discarded cigarette. Stopped my car, took out my 2-1/2 pound Purple K extinguisher, pulled the pin, squeezed the handle, and Pffft!, it emptied just like that! I carry only 5-pound ABC extinguishers ever since.
I don't have a lot of solutions for the mount issue, but hopefully my thoughts will generate ideas from other forum members.
1996cc
Oregon
21 JLUR 392
I have the Cooltech mount too. it is an easy install and is quick to remove in emergency. It works just fine with the Dominion offload Hi-lift mount for those that have one.
How does the Cooltech actually attach to the rollbar? It doesn’t specify on their site.
77RRAD
Ron
Las Vegas
2019 JLUR
With the 2.5 lb bottle the extingusher can slide up about 1 inch then hits the cross bar so it cannot slide out.
There is also no rattle that I hear.
Dan S
STL MO
'18 JL Sahara
Elevator Mechanic Apprentice
It bolts into the large hole on the backside of the roll bar and one of the smaller screws secures the bottom section. It seems really solid and secure.
