Smartbar Sway bar disconnect Control Board
Nordy
Mitch
Wisco
JL Rubicon Blue
Anyone have some experience in finding a control board for the sway bar disconnect system. I smashed thru the front stock skid plate wheeling by hitting something hidden in the mud! Of course Jeep Engineers decided this should be a CAN device, so they can check state etc. and add auto re-engage features easily, but everything went haywire when it was smashed. Now that's not a huge surprise when you short a CAN bus, so I was unable to disconnect the electronics and throw the ends in a bag, tape them up and keep on driving. I definitely want to fix it, and add a lot more protection up front for wheeling. I could try to solder up the board as is by the looks of it but the top corner has few broken resistors and a cracked board, which probably means cracked traces.
So really I'm looking for a new control module with the plastic connector piece connected....Or worst case if someone is willing to share the CAN protocol & messages of this device I can fab up a new control board, but without a working system it's pretty hard to reverse engineer CAN messages! I drilled out the rivets for now and will thread and tap the holes and fab up a new connector if I can get just a board. I'm not interested in the old, hey get a manual one option either...I'm too lazy to have that as a long term fix! lol
Nordy
Nordy
Mitch
Wisco
JL Rubicon Blue
CaJLMetalHead
CAJLMetalHead
Jeep Wrangler Sport Unlimited
Hey!.. I know this is an old thread.. but I have been working on getting a smart sway bar from a Rubicon in my Sport..
There is a lot going on in this thread about CANBus hacking.. and somebody recently found the CANBus sway bar codes!
https://www.jlwranglerforums.com/fo...rnet-the-wranglers-can-bus.82139/post-1782181
I will be working on getting a ESP32 running at some point in the coming weeks in order to be able to control the sway bar...
TKL223/3
Jon
Arkansas
Jeep JLU Rubicon
Life is so much easier to remove the motor and add an Evo no limits disconnect
CaJLMetalHead
CAJLMetalHead
I know!.. that is actually what I did with mine (well.. I fabricated my own from scrap parts because I am a cheap bastard) ... however... if you are a geek like me.. then you rejoice in getting to understand how these over-engineered pieces of off-roading equipment work and how to repurpose them.. 🤓 👍
