Slightly bent B-pillar on the driver side
afterdarq
Bulgaria
2019 JLU Rubi
hi guys, new jeep owner here. Had the audacity to buy a damaged 2019 JL Rubicon (accident was a rollover offroad) and so far the repairs have been relatively simple (the roof excluded) with the exception of the slight bend in the top of b-pillar on the driver side that is causing fitment issues. It's about 0.2inches or so bent inwards. I know Jeep used some new blow-formed tech for the new sport bars as they call them. It can surely be fixed with a pull, but does anyone what is the repair procedure for this or have any other suggestions. Any help or inputs as well as schematics will be greatly appreciated.
Sorry for the lame pic, but it has been pouring hard for several days now, I can't get a proper photo.
JasonInDLH
Jason
MN
21 JLUR, 15 Yukon Denali
I’d Rather Talk Jeep’s!
My initial thoughts would be to remove the interior trim in that area and see if you could tap it back into place. I’ve only owned my JL for a short while and don’t even remember what’s behind that part, so maybe this idea won’t work?
afterdarq
Bulgaria
2019 JLU Rubi
the B-pillar basically constitutes of 3 parts shown here
Jeep Wrangler JL Slightly bent B-pillar on the driver side e5a78248811743198befe13220f1089a
Problem is, I believe all 3 are welded to each other and also to the newly designed sport bars that are supposedly super-tough, but apparently not so much:
Jeep Wrangler JL Slightly bent B-pillar on the driver side great-designs-and-steel-20190515-45
I would have wished for this to have some sort of assembly that can be replaced, but maybe the only way is to pull it slightly in the opposite direction.
DaltonGang
Houston, Tx
Old school time. Wrap the B-Pillar in towels. Get a large rubber mallet, and do some whacking. A little at a time. Just my thoughts.
Let us know what you decide, and what the results are.
afterdarq
Bulgaria
2019 JLU Rubi
Yeah this is most likely the approach I will take. I need to find a schematic how to remove the interior trim on the pillar. I've had bad experiences with breaking interior trims and don't want to cause unnecessary additional damage. I basically need access to something like this (taken from the B-pillar weld TSB):
Jeep Wrangler JL Slightly bent B-pillar on the driver side 1634121193054
Glamisfan
SoCal, 30 minutes from Glamis
2020 Sting-Gray JLUR
I would remove the rear door, put a 2 or 3 foot block of wood on the b pillar, and hit the wood with a 3 lb hammer. I would only concentrate on making the gap even. A 1/4 inch off at the outside of the b pillar hopefully/probably didn’t affect the inner part of it. If your not comfortable with that then a body shop can knock it back in place.
DaltonGang
Houston, Tx
I thought about the wooden block too, but It might damage the paint. You could wrap the pillar in a towel, then use the wooden block against the towel, for more accuracy, and less of a chance at bending an edge. Or, wrap the block of wood with a cloth.
afterdarq
Bulgaria
2019 JLU Rubi
Thanks, I will try not to damage the paint, but if I manage to get this fixed somehow, I am willing to sacrifice the paint if necessary. Do you know what the steps are for the internal trim removal, does it start with the bolts that connect the roof or the ones that are for the speakers?
DaltonGang
Houston, Tx
No idea.
