Sliding in the wet. Jeep thing or better tires?
  1. MrBell
    MrBell Member
    First Name:
    Christopher
    Vehicle(s):
    Shopping for JL
    Jul 30, 2019
    Washington State
    Liked:
    New JL owner here in the rainy Pacific NW. I've had a few "fishtail slides" when going around long corners on wet pavement. Disconcerting to say the least... I get the high center of gravity is at work here and I'm taking it easy in the rain. I've also been running in 4H which helps. I've turned my attention to the stock Bridgestone Dueler's... I'm curious to hear other owners rain tire recommendations. My Wrangler is a Sahara.
    Thanks in advance.
  2. quietpeen
    quietpeen Well-Known Member
    Vehicle(s):
    2019 JLUR
    Jun 26, 2019
    Chambersburg, PA
    472
    Liked:
    280
    Im not so sure it’s the tires, might be the short wheel base with like you said higher center of gravity. I recently had it happen in my Jeep with nitro ridge grapplers (that have roughly 2000 miles on them)on a 90 degree turn while I wasn’t even on the gas. I don’t think I was going any faster than I have recently in rain with my car or the ram 1500 with mud tires that I traded in on the Jeep.
    MrBell likes this.
  3. offset_98
    offset_98 Well-Known Member
    Vehicle(s):
    2019 JLU Sahara, 1993 Nissan 300ZX, 2015 Subaru Outback, 2011 Toyota Sienna
    Mar 20, 2019
    Tampa, FL
    182
    Liked:
    143
    I’ve never fishtailed in the Jeep with the tires it came with (Dueler A/T’s). Will see now that I have M/T’s on it. I’m also pretty light on the throttle in the wet. This is my 5th RWD and growing up in Chicago driving a Crown Vic, you learn what not to do, lol.
    Kraty1 likes this.
  4. quietpeen
    Vehicle(s):
    2019 JLUR
    Jun 26, 2019
    Chambersburg, PA
    472
    Liked:
    280
    This is far from my first rodeo in a rear wheel drive vehicle and I wasn’t even on the gas when this happened. I will say it wasn’t so much a fishtail as much as it seemed like the whole vehicle slid, but like I said I wasn’t going any faster than I did in other rwd vehicles and one was a truck with dedicated mud tires.
  5. offrampclimber
    offrampclimber Active Member
    Vehicle(s):
    JL Unlimited Sahara
    Mar 1, 2018
    Indiana
    32
    Liked:
    That's essentially all there is to it. It's a tall vehicle with RWD. It may occasionally slip in the rain. Different tires aren't going to help. How many miles do you have on them? Brand new tires aren't quite broken in, and I've noticed traction on 30,000+ miles starts to get a tiny bit sketchy. But just take it easy on the throttle and learn where that slipping point is.
    It's happened to me in my current JL with the Bridgestone A/Ts, my old TJ with a variety of tires, and one pants-shitting moment, years ago, in an XJ with BFGoodrich KO's. I wouldn't recommend using 4H in the rain, but some people say it won't cause any wear and tear, so to each their own on that.
  6. wcjeep
    wcjeep Well-Known Member
    Vehicle(s):
    YJ
    Jan 12, 2019
    Earth
    53
    Liked:
    What tire pressure are you running?
  7. marek
    marek Well-Known Member
    First Name:
    Marek
    Vehicle(s):
    19 Jeep Wrangler Moab 03 Mercedes SL 500
    Mar 8, 2019
    Nashville TN
    62
    Liked:
    86
    From my understanding, I also think don’t use 4H in the rain. 4H Auto by all means, but not 4H. Curious what other more experienced 4WD members think.
  8. OP
    MrBell
    MrBell Member
    First Name:
    Christopher
    Vehicle(s):
    Shopping for JL
    Jul 30, 2019
    Washington State
    Liked:
    I'm running 38psi.
  9. Shepherd12
    Shepherd12 Well-Known Member
    First Name:
    Josh
    Vehicle(s):
    18 JLR HellaYella m/t
    Dec 12, 2018
    Wilds of PA
    223
    Liked:
    233
    Occupation:
    Something about cryogenics
    You might let a bit of that pressure out and see if it helps. OR you could learn to drift.
    AnnDee4444 likes this.
  10. Benagi
    Benagi Member
    First Name:
    Ben
    Vehicle(s):
    2018 Wrangler Unlimited Sport
    Oct 21, 2019
    UT
    Liked:
    I don’t think our sport has 4h auto. Can we drive it in 4h on wet roads?
  11. Jeepdude101
    Jeepdude101 Well-Known Member
    Vehicle(s):
    18 Jlur
    Oct 28, 2019
    Arlington Texas
    117
    Liked:
    89
    Garage Profiles:
    I wouldn’t and 4h only helps with acceleration not braking and turning it might help a little just because there would be understeer but try lowering your air pressure first happy jeeping:like:
    HoundDude and Boatbuilder88 like this.
  12. marek
    First Name:
    Marek
    Vehicle(s):
    Mar 8, 2019
    Nashville TN
    62
    Liked:
    86
    I don’t think 4H Part time at higher speeds is helping stability at all. Especially going through the curves.
  13. OP
    MrBell
    MrBell Member
    First Name:
    Christopher
    Vehicle(s):
    Shopping for JL
    Jul 30, 2019
    Washington State
    Liked:
    I lowered the pressure down on my tires to 35. This has made a significant difference on wet roads. My Wrangler feels much more planted and stable on corners. I did not "fish-tale" once today. I don't feel the need to put it in 4H now. It is also much more comfortable on the crappy Seattle roads.
    HoundDude and wcjeep like this.
  14. Jeepdude101
    Vehicle(s):
    18 Jlur
    Oct 28, 2019
    Arlington Texas
    117
    Liked:
    89
    Garage Profiles:
    Psi makes a HUGE difference on and offroad glad it helped:like:
    MrBell likes this.
  15. Lil Punk'n
    Lil Punk'n Well-Known Member
    First Name:
    Richard
    Vehicle(s):
    2018 wrangled jl sport
    Jan 13, 2019
    Talmoon Mn
    159
    Liked:
    226
    Occupation:
    Retired, School bus driver
    Run the pressure down to about 34 & remember short wheel base turn on a dime. Slow down your not in a race. Just the thoughts of a oldtimer.
Loading...
Share This Page
