Sky one touch rattling..driving me nuts!
JeepCares
Auburn Hills, MI
JL
MoJoJoJoJeep and JeepCares - any luck with a fix? I’m on trip 4 or 5 now with two drive alongs with the service tech to find the noise. I had a trim piece that was loose, replaced now, and the noise comes back over the front passenger door with the top retracted. Additional noise is above the passenger rear door/rear window area and they think there is a washer missing. The tech put a few pieces of paper shimmed in there to see if it goes away. It kind of did, but still wondering why there are pieces missing on the assembly?? I live in a small town and this is the first SkyOne-touch power top that they have seen and are really lost on a fix. I have a third noise coming from the passenger rear window and am so frustrated! Why is the drivers side so solid and only the Passenger side is making noise?
Sorry to hear of your concerns, Pabst113! Send our team a private message with more details so we can assist further.
Kate
Jeep Cares
Pabst113
South Carolina
2020 Jeep Wrangler Unlimited Willy’s
Kate
Jeep Cares
I already sent a private message a few days ago but will resend.
Thanks!
Pabst113
South Carolina
Sorry, Pabst113! I see it now and will follow up with you there.
Kate
Jeep Cares
I am stillworking with JEEP care and my dealership but we cannot determine the cause and fix for my rather annoying squeaking from the rear passenger door area of the top. The next step is to use a syringe and water to lubricate some areas of the top and if the squeaking goes away they’ll use LockTite 290injected to seal it. Has anyone else experienced this? Video attached should have the annoying noise that visits with every bump.
MoJoJoJoJeep
Lori
2020 Rubicon Unlimited 4 door
[/QUOTE
Pabst113
South Carolina
MoJoJoJoJeep - did you have an idea about it? It looks like your reply didn’t go thru.
MoJoJoJoJeep
Lori
When I had that sound it seemed to come from the pins at the rear windows that are removable. Have you tried the Teflon tape there? Or a replacement latch?
e at those pins?
Pabst113
South Carolina
I am going to try that. My Jeep came with the Teflon tape on the latch mounts. I’m going to take the window out and see if the noise disappears. Thanks for the info, maybe it’s just the latch!
Pabst113
South Carolina
Well, the latch seems to be the issue. I have the Teflon tape, but I had my son in latch the window while the noise was going on. Immediately after he unlocked it, the noise stopped. It stayed away for a bit and then returned. I unlocked/locked it again and the noise stopped for a bit then returned. Looks like the latch to me! Thanks for the input MoJoJoJoJeep!
MoJoJoJoJeep
Lori
I’m so happy you found the sound
df007
2019 JLU Sahara 2.0
I've also been "chasing" a latch rattle. I tried the anti-stick tape all over it, then I bought new latches and it still returned. This weekend I took all the tape off the latch and matching side of the steel strike plate, and instead unbolted the steel strike plate form the top and put some tape on the two sides of the strike plate where it mates to the top itself, then bolted it back in place, pushing it firmly into the matching top profile. So far it's been a few days and my rattle has not returned.
Pabst113
South Carolina
That makes sense...where’d you find the Teflon tape? I haven’t been back to my dealer yet since I’m out of town now, it want to have a solid plan for when I return to rid the Jeep from the one thing I strongly dislike about it!
df007
2019 JLU Sahara 2.0
I used this stuff
TapeCase - 1-5-423-5 423-5 UHMW Tape Roll 1 in. (W) x 15 ft. (L) - Abrasion Resistant High Tack Acrylic Adhesive. Sealants and Tapes
by Amazon.com
Learn more: https://www.amazon.com/dp/B00823JF0S/ref=cm_sw_em_r_mt_dp_EE5DX44VQX4EGXKCXP9B?_encoding=UTF8&psc=1
2mnycars
Canada
JLU
For the couple things I mentioned, those definitely were actual fixes for me. Mine technically was 2 visits for the sky top making the noise. One for them to diagnose and the next once the foam came in for them to do the repair. The other one I fixed on my own lol. I had immediately starting noticing the rear removable window area making noise after the top noise was fixed! Luckily I solved that quickly, but that has lasted for 6 months now! The sky top fix the dealer did has been perfect ever since. I think getting every dealership to understand what we try to explain to them is part of the problem.. luckily my dealer knew immediately what I was describing since they said the 2019 Jeeps had the same issue. Would have been nice for jeep to fix that for my 2020! Lol
I had issues with the selling dealer not confirming problems with the Wrangler. Turns out their service drive was only 6 minutes long, at low speed on smooth roads.
I wish they would allow me to ride along to show the tech when problems occur. Like highway speed for steering issues....
JTopsUSA
