Sky one touch rattling..driving me nuts!
trailchaser
Javier
Haymarket, VA
2019 Moab
Picked up my JLUR last Thursday, on Monday I noticed a rattling noise that’s been driving me crazy..just now as we head to dinner I let my wife drive and I went in the back....the source seems to be the latch near the driver side removable window for the sky touch...not 100% but seemed to get better once I undid it.
I paid 55k after all discounts and it drives me nuts that at 400 miles this 61k car is already rattling...love it otherwise
Help!
Roy_Hobbs
Roy
Rochester Hills, Michigan
2019 JLU Sahara Ocean Blue Sky One-Touch
Take it to the dealership and they will fix it. Mine had the same issue on the passenger side. It’s quiet now unless I hit a large bump/pothole
Bricazo
New Jersey
2019 Moab
I had the same thing. Get a little grease or wd40 and lube where the latch on the hard top and the pin on the window handle meet. I did it on all 4 latches and been silent ever since. Going on 5 months
trailchaser
Javier
Haymarket, VA
2019 Moab
Could you take a pic for me of the spot please? I have a Sky top so not sure which part you are referring to
Thank you!
trailchaser
Javier
Haymarket, VA
2019 Moab
Can you please let me know what they did? Would prefer to do it myself to avoid the time going there, thanks!
Bricazo
New Jersey
2019 Moab
Thank you!
Right where the handle grabs onto the top. It’s metal on metal so if you grease it it should stop. Also make sure the locking handle screw that holds it to the window is tight. I’ll take a pic for u tomorrow of mine if u still don’t see it
trailchaser
Javier
Haymarket, VA
2019 Moab
Is this it?
trailchaser
Javier
Haymarket, VA
2019 Moab
correct , a little grease on both and mine stopped. Not sure why they put metal on metal when you know it will make noise. If they were rubber coated that would have solved it all.
Sweet, did you grease the peg or just the top? I may try putting a rubber pad there too...excited to see if it solves my issue...appreciate you brother!
Bricazo
New Jersey
2019 Moab
grease both and see if it works.. Also I checked all the bolts that hold the top on around the bottom where it attaches to the jeep. I hope it works for you.
JeepCares
Auburn Hills, MI
JL
Help!
Hi trailchaser,
Sorry to hear that you are experiencing this concern with your new Wrangler. If you are not able to remedy the concern with the advice provided here, we kindly recommend connecting with your local Jeep dealer. We are available via private message if you are in need of any assistance with that process.
Jeep Social Care Specialist
margojon
Jon
NY
2019 Sahara Wrangler
so crazy this was posted, had the same issue and waiting for the dealer to get in some part that they think will fix it...and we thought we were the only ones!
Memphis Peej
PJ
Memphis
Pilot, Acura TSX, 2019 Moab!!!
Same here!
GibbonsMonkey
GVRD
JLUR; R1200GSA; Goldwing
Ditto. I normally just pull the window and reseat it every week or so. It seems to quiet it down.
Gibson Leatherworks
