gamecocks9799
- John
- Dec 20, 2019
- Ashburn, VA
- 2020 Jeep Wrangler Rubicon
- Occupation
- Consultant
There have been a few posts on this already, but some steps or photos were missing so I thought I'd post this.
My 2020 JLU Rubicon with Sky One Touch top finally had the front rivets sheer off which prevents the top from securing tightly to the frame. The tension strap ends up being loose and the top will lift from the track in the wind. Here is the progression. First, my passenger rivet broke. I removed the rivet, put a screw in and thought how fantastic I was. Then, 2 days later, it was broken again! The screw was still in place in the bar; however the nut had rattled loose and the strap came out once again. I also noticed that the driver side rivet also failed! So I had 2 failed rivets (and a failed repair, smh). I decided to use Loctite this time and it worked like a charm. It's been holding up GREAT for the past week. No downtime at the dealership. No new top. No issues. So, here are the steps:
1) Crush and remove bottom part of the rivet below the bar with vice grips (repeat until mostly flush with bar and bottom removed).
2) Gently punch the rivet up through the hole to un seat any remaining portion that is grabbing. Use Hammer and Nail Punch.
3) Once dislodged slightly, use vice grips from top to pull rivet out of hole.
4) Install #8 - 1/2 Inch Flat head screw with nut and loctite threadlocker (Bar/Strap/Bar)
The screws and nuts cost $4 from Lowes. The loctite cost $7.50 (I used the Blue 242).
The photos are attached. Hopefully this helps others. Thanks to the others on the forum that have done this ahead of me.
