Skid Row Exhaust Loop Skid Plate "Improvements"
CarbonSteel
CarbonSteel
2023 Ford Bronco Wildtrak
Not really. I used an adjustable wrench on the nut because my big wrenches weren’t handy (22 I think) and a socket/air impact on the 21 bolt head. You don’t have to remove the bolt, just take the nut off, place the skid, bolt it back up and torque it. Total install time less than 5 minutes.
Good to know, it looked to be a pain, but I was balancing the skid and a tape measure at the same time.
LazyJL
Larry
2020 Rubicon, 2001 built XJ, 1997 near stock XJ
Retired fabricator and mechanic
Interesting that the only exhaust loop skids I found searching are the Skid Row plate and the EVO skid plate
it appears that none of the big buck full skid plates manufacturers consider the exhaust loop worth protecting.
My question is the exhaust loop less vulnerable than it appears? It looks expensive to replace.
CarbonSteel
CarbonSteel
There have been a few posts where some one has damaged the loop and yes, it is not cheap to replace. The EVO skid plate does not appear to protect as well as the Skid Row version if I am understanding how it works.
DaddyEngineer
Tomball Texas
2019 JLU Rubicon
Not sure, but the Evo skid looks like it only works with their belly skid system.
CarbonSteel
CarbonSteel
@Chocolate Thunder - here it is after I gusseted the tab, fully welded the parts they stitch welded and added some additional flat bar to strengthen it. Just out of the sandblaster and I will test fit it and then have it coated:
Pig-Pen
Eastvale, CA
2018 JLU
jabroni
i have had the skid row plate for over a year now. i have room between it and the loop. Choco Thunder, is yours a 2.0T by any chance?
CarbonSteel
CarbonSteel
The 2.0T does not have the exhaust loop.
Chocolate Thunder
Jeremy
No, 3.6L automatic.
unsavory
Jimmy
2022 JLUR XR 2.0T Auto, 2019 JLUR V6 Manual (sold)
I can't stick my finger in there, but there appears to be about 1/8th inch between my skid and the heat shield.
sherpaJL
on a Summit
2019 JLUR Mojito! ~ 2022 JLUR Hydro Blue
Jeep Wrangler JL Skid Row Exhaust Loop Skid Plate "Improvements" qljYcF
did you ever get this installed?
I'm debating between skid or loop delete downpipe
CarbonSteel
CarbonSteel
Yes; I did, but it required removing the heat shield from the loop to gain enough clearance. In the end, it is not really a big deal, but Skid Row should have done more research before going to market.
I went out on their website a few minutes ago and they may have "improved" it over the version that I have. It appears to be a little wider than mine.
After I beefed mine up, I have been happy with it because it took a hit that would have certainly dented the exhaust loop or without the extra bracing I did, folded up into the exhaust loop.
