Kreepin1
- Kirk
- Oct 27, 2020
- Central Illinois
- 1982 CJ7, 2006 TJ, 2012 JKR, 2021 JLR
- Build Thread
- Link
I believe the OP is running 295/70R18 tires on 18x8 wheels with a +30 offset. The tires you have in mind are the same height but nearly an inch wider...Hello sir, great wheels on your rigs there. I’m currently planning on getting a 315/70R17 tires with 17x9 rims, however, most i’ve seen have negative offset which makes it the tire poke out further from the fender.
with your setup (17x8 with +30 offset right) i might go with this route, the stance looks great. I won’t be doing any heavy rock trailing. Any rubbing you experience so far on full lock or the fender liner?
