ToPar9
- Mar 16, 2020
- North Texas
- '19 JLU Altitude
Hello, all. I installed the Sidetrack LED lights last night. I want to add a few additional details, tips, tricks, what have you.
- I was skeptical of removing exterior rivets, so I went a different route. I removed the fender and fender liner, all as one piece. 5-10mm bolts, 1-push tab, and a little yank. Once the fender is halfway off, disconnect the lighting harness, then pull the rest of the fender off. I purchased a pack of the fender tabs off of Amazon for 8 bucks. I only needed one tab as the rest either stayed in place or were easily reattached. if the white clips stay on the vehicle, reach a pair of needle-nose, pinch the tab and slide it out.
- I was worried about feeding the yellow wire through the rubber grommet after reading a few horror stories on here about inadvertently cutting wires. I found the perfect spot to feed a coat hanger through the grommet.
I added a few pictures to help my explanation. The pics should help show a better example.
**One last thing**
I installed the Smoked LED Sidemarker Lights as well. With the fender off, and a 16" skinny 27 Torx, the need to remove the front fender exterior rivets was not necessary. A little patience and guidance, allowed me to remove the stock sidemarker light and install the smoked lights. It was a very simple task that maybe took 5 minutes with the fender off.
Everything is in perfect working order!
I put together a little video, (I won't be the next Spielberg), but I shot it in my garage with minimal light. The LED's are BRIGHT.
Attached are a few of the steps mentioned above.
Oh yeah ... Oracle ... next time, wait until the fall for sweet releases. Summer - North Texas - Garage - Waaaay too hot! haha
**One last thing**
