Side View Mirror replacement on a JL/JT (DIY instructions)
Rhinebeck01
2018 2dr. Rubi
Something you as a JL or JT owner might very well find yourself wanting/needing to replace is the side view mirror(S) .
The JLJT's side view mirror is a tad easier to deal with then the JK's side view mirror.. Only takes about 10 min to do ...
Mopar side view mirrors cost approx. $130+-
Mopar 68281891AE Power Mirror for Driver Side on 18-21 Jeep Wrangler JL and Gladiator JT
Mopar 68281890AE Power Mirror for Passenger Side on 18-21 Jeep Wrangler JL and Gladiator JT
Anyway, a decent / short video showing how to do the side view mirror replacement is worth a thousand words.. 8-)
Rhinebeck01
Rhinebeck01
2018 2dr. Rubi
IF, you go to replace a side view mirror on a JL/JT and find a plastic covering over the 3 retaining bolts that hold the side view mirror.... Do know that the plastic aftermarket cover you see is held on by double sided tape. Just use a hair dryer to gently heat the cover and then carefully pry the cover up. You will need new 3M double sided tape to re-install the cover.
Jeep Wrangler JL Side View Mirror replacement on a JL/JT (DIY instructions) 81mPWaNAItL._AC_SL1500_
Jeep Wrangler JL Side View Mirror replacement on a JL/JT (DIY instructions) 81COFwdg-yL._AC_SL1500_
Nolafireman
popcorn
Richmond
2018 JL Sport S
I have the power and heated mirrors on my JL Sport. My mirror was broken by a bicycle rider. Could I replace it with a mirror that also has blind spot detection? If so, could I get the detection to work?
Rhinebeck01
Rhinebeck01
2018 2dr. Rubi
@Nolafireman
No and No ....
