- Feb 15, 2017
- West Chester, PA
- Website
- www.quadratec.com
- CJ, YJ, XJ, TJ, JK, JL
We are adding to the Carnivore line-up. Our popular Carnivore Front Bumpers currently come in three different sizes; Full-Width, Mid-Width and Stubby. These heavy-duty front bumpers are available for the Jeep Wrangler JK and JL as well as the Jeep Gladiator JT. To compliment and continue the great looks, we are releasing matching Side Steps and Rear Bumper for the four-door Jeep Wrangler JL Unlimited.
The Carnivore Side Steps are the perfect blend of form, function, and strength. The aggressively styled step will match the striking Carnivore Front Bumper to enhance the look of your Jeep Wrangler JL. These protective side steps fill the space between the wheel wells with a landing area the makes entering or exiting your Jeep a simple and confident motion. With a little over 6-inch platform that is 72-inches long, the step provides easier access to the roof for cleaning, removing freedom panels or soft top or when loading/unloading items from a cargo rack.
The unique Carnivore styling continues with the distinct mesh stone guard on each end of the step to compliment the ones found on the bumper. These guards could be removed and painted to match the accents on your Jeep for even further personalization. The platform features a reverse dimple tread pattern design to improve traction and enhance the rugged appearance. The black textured powder coating on the platform and all the brackets adds long-lasting durability and a great looking finish to any Jeep. Installation is relatively simple with no drilling or welding required.
The Carnivore Rear Bumper for Jeep Wrangler JL Unlimited is built to protect your vehicle from the toughest trail conditions with its unique styling that is sure to turn heads. The heavy-duty steel Carnivore Rear Bumpers are laser-cut from 5mm thick carbon steel plate, 6mm thick frame mount brackets and robotically welded for precision and ultimate strength. Protect the rear of your Jeep with a bumper that measures 65-inches wide. The rear bumper accommodates the factory rear backup sensors, if equipped, and up to a 35-inch-tall spare using the factory spare tire mount. Behind the stylized mesh stone guards are auxiliary light brackets where you can mount your favorite light pods. These mesh stone guards give an aggressive off-road look that can be removed, prepared, and painted to give that customized look to match your Jeep. The bumper is designed to work with factory and aftermarket tow hitches and includes a license plate mounting bracket with led lights and a plug-and-play wiring harness. The 1-inch-thick D-Ring clevis tabs provide two functional recovery points, and the black textured powder coating provides lasting durability. Enjoy the easy direct bolt-on installation that doesn’t require any drilling or modification.
https://bit.ly/3v30AC1
https://bit.ly/3HOMFHu
