AaronTV
I have a 2021 Wrangler 4xe Sahara with zero mods and ~5500 miles.
It may be a coincidence, but the following started happening immediately after I had the Jeep in for software updates a couple months ago. But I had also placed the transfer case in 4A around the same time in anticipation of the coming winter months.
I was driving it home from the dealer and, after hitting a bump in the highway, the entire vehicle started shuddering/vibrating in a very alarming fashion. I actually wondered if a wheel had come loose, it was that dramatic. I started to slow down and prepare to pull over but it stopped doing it after about 10 seconds.
Since then, I've noticed more subtle versions of the shudder/vibration whenever I go over a bump or crack at highway speeds, usually lasting for only a moment or two. It has done the 10 second-ish prolonged version 1 other time (for a total of two).
I had immediately alerted the dealer about this back when it first happened but the service advisor didn't seem concerned or didn't understand what I was trying to explain.
The alignment seems OK, the Jeep stays straight on the road if I take my hands off the wheel. I don't hear any odd sounds or creaks from the suspension.
But these shudders/shaking/vibrations are very disconcerting when the the "long" version happens.
Any thoughts?
Any thoughts?
