Shredded Gears or broken Axle Shaft
Mandalorian
MANDALORIAN
Las Vegas
2019 JLU SPORT
Feel into a v notch twice yesterday and trying to get back out I heard a snapping/ Kachunk a couple times then 4x4 was no longer a thing. I had to be winched back and it seemed to be in 4x4 reversing down some obstacles but when I went to cut it sharp to drive out the snapping noise occurred again and then there was for sure no 4x4. Driving in 2 wheel drive had no issues.
I've never shredded gears before but always assumed it would be more of a rattling noise with all the small metal pieces vibrating around. Before pulling it apart is there any way to know if it's one or the other
I daily my jeep so I'll still be going back and forth from work so if there is a way I could tell I'll order the part first then only have to pull it apart once.
CarbonSteel
2019 Jeep Rubicon Unlimited
You can put it in 4H, jack it up, pull the axle cover, and spin the tires to see what is happening.
Digger 5
Pacific NW
JK
You'll want to find out what is wrong ASAP. If it's an axle shafts, all the junk from the shaft is going through your diff and bearings. It can easily require you to do a gear swap due to the debris.
With a gear failure the collateral damage isn't usually as bad however I have seen diffs lock up and take out the t-case and/or driveshaft.
D60
CO
JL
Have you put eyes on the shafts at the knuckles?
Why are we all assuming worst case zebra stuff? You probably snapped a u-joint and subsequently destroyed the ears on one or both shafts.
Look for the most common stuff first.
Mandalorian
Mandalorian
MANDALORIAN
Las Vegas
2019 JLU SPORT
I don't know what zebra stuff is. There is no visible damage. I'm trying to avoid pulling it apart twice. If you have any info on how to decifer what part/ parts need to be ordered without pulling it apart that would be appreciated.
The u joint and ear was brought up to me by a friend and is the area where the snapping noise came from.
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
I think it's a reference to an old medical adage; something like "when you hear hoof-steps think horses not zebras" basically meaning, don't over think it, it's likely the most obvious culprit.
I'll let someone more qualified help you with diagnostics, but I do believe I would be doing some investigating before daily driving the way it is.
sourdough
Strider
white JLR
wanderer
This is pretty basic 101 stuff. If it happened when your front wheels were turned all the way, a front axle shaft u-joint most likely has failed, big time. You can see the u-joint because Wranglers have open style knuckles. Turn the front wheels all the way, get down and dirty for a look. This video starts by showing an inspection of a u-joint that is worn out, your issue will be easier to see...
Sounds to me you drove it home in 2wd. You could do that if the axle has broken into two sections. I would not drive it any further.
Sheepjeep
Ma
01 xj, 04 Silverado 2500hd
you need to inspect it to figure out what is wrong, inspect the u joints lift the front off the ground see if you can get a better idea by spinning the tires freely, pull diff cover see whats missing, pull hte shafts see what comes out
you really dont want to drive it until its fixed it will make the problem worse for you
Mandalorian
Mandalorian
MANDALORIAN
Las Vegas
2019 JLU SPORT
This is the type of answer I was looking for. I'll check it out later today and see what I find. Thanks.
Mandalorian
Mandalorian
MANDALORIAN
Las Vegas
2019 JLU SPORT
Checked it out. No visible damage to the ujoint and no play when I jack it up and spin the tire. I did find that the front drive shaft spins freely in both directions but will occasionally get hung when rotating to the right to the point where I have to rotate into the left a few times to spin it back again with no resistance to the right.
CarbonSteel
Pull the cover--you will only be able to assume what is wrong until you do.
Mandalorian
Mandalorian
MANDALORIAN
Las Vegas
2019 JLU SPORT
Followup:
Upon original inalienable it was the slider gears. I ordered new gears for $103 from yon but once I pulled the diff I noticed the pinion was damaged. Time to do the full regear I guess
word302
Oregon
JLU
Followup:
Bummer, but at least you get new gears.
Morris4x4
Rock Sponsor (Level 1)
Morris 4x4
www.morris4x4center.com
JL, '13 JK
Followup:
I kinda figured that would be it. Glad there isnt more damage done though!
Last time I busted gears (due to bad gear set up by a company) it sounded like a train rolling through moab. Had to drive from gemini bridges to the sand dunes where camp was.
Hothead Headliners
