Mcmett824
How are the rokblokz on the 4xe? Do they fit as expected? I understand the fenders and fit for 4xe rubicon are different than regular rubi. Looking to order some if they'll work.Hello all,
I recently got the mopar ‘2”’ lift and 37” BFG KO2’s installed on procomp 17x9 7069 series rims.
I am posting these pictures to help others make a decision as I would have appreciated the same during my research phase.
It is worth noting this is my first Jeep though I have reasonable mechanical experience from the past.
I’ll start with the normal flat ground photos:
I don’t have a spare tire carrier yet, it seems they are in short supply. The 37” spare does fit in the back but you will need to put the rear seats down.
Then I set the tires straight and lifted the front passenger tire using a forklift:
I neglected to get a front or offside photo at max lift but the tires will rub the trim at this point.
I am thinking of installing longer bump stops to prevent this or try heating and remolding the trim.
Then I set the tires at full lock to see how high I could lift it before the tire hits the bumper:
Hopefully this helps shed some light on what running 37s looks like and means.
In hindsight I should have measured the max heights and corresponding distance to bump stops.
Thank you guys, any advice you can give regarding improvements to this setup to prevent rubbing and maximize articulation would be appreciated.
