Should i buy A Bestop Trektop NX Soft Top
Which soft top would you get
  • Total voters
    112
2008jk
Anoka,Mn
2008 JKU
I received and replaced top fabric, rear window, and new larger seal on tailgate bar. New top and rear window now have Velcro at top of rear window for flapping, and new seal to fill in space between bar and tailgate.
StrikeZ
TJ
Maryland
2018 Jeep Wrangler Rubicon Unlimited
I will need something, my back flaps like crazy at 70 mph. My double seal just falls off. Is calling or emailing the best approach? @BestopTeam
ParthianShot
For the seal, I figured out you can pinch the channel back together, as it just gets loose. I used a pair of pliers with moderate pressure along the entire seal, then put it back on. It's good to go again.
ParthianShot
Just to update everyone, Bestop replaced my top w/ a new one. I finally got around to installing it, and it's a ton better. Every single problem I had with the last one has been fixed. No more flapping from either fabric or window, and the tailgate bar seals up perfectly with the tailgate. They really went above and beyond once they got to my case. I now am in love with this soft top. THANK YOU @BestopTeam!!!
jtf2020
J
2018 Wrangler JL 2Door
For people that have the Bestop - If I wanted to take off the top (not the hardware) how long does it take? Also how long to reinstall the top (not the hardware)?
Sean L
Sean
North Carolina
To take the top canvass all the way off you need to take the hardware off... otherwise you'd spend an hour doing what could be a 15 minute job.
