Shock upgrade
DadJokes
Daniel
Indiana
www.youtube.com
Sahara
Rubicon suspension up front with 3/4 spacer. The rear has “1” Synergy springs. I do carry considerable weight on our trips and the Jeep appears to have a factory rake when loaded so in that circumstance, I’m unsure if longer than stock shocks are needed. Correct?
Really, I’m looking for a little better ride on the trail. A simple adjustable setup might be interesting to me.
I suppose I might need to take measurements to verify whether stock length shocks or longer is needed. If longer is needed, considering my ride height loaded, would I need different bump stops?
Thanks for any help.
DadJokes
DadJokes
Daniel
Indiana
www.youtube.com
Sahara
Bump. Anyone? Any shock guru’s to point me in the right direction?
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
Best way if you have the time and patience is to pull springs and cycle suspension to get measurements.
DadJokes
DadJokes
Daniel
Indiana
www.youtube.com
Sahara
Fun. The Jeeps ride might not be that bad come to think of it. lol
AccuTunedJL
El Cajon, CA
2018 Jeep JL Rubicon
If you can get shock length measurements, you can compare that to where the shocks sit at ride height. That will give you a good idea on how much up/down travel you have. Lifting the Jeep higher and keeping the same length shocks will reduce your droop travel from ride height. May not sound like a big deal, but it can affect your ride quality. However within 1" of added lift, shouldn't make a huge difference.
AnnDee4444
'18 JLR 2.0
