Old Jeeper
Quite impressed in your research and you skill with MS Excel, I applaud you...I've had a few people ask for access to my shock & spring charts, so I decided to put all this in a sharable format that anyone can access or download & modify. There's more than one tab at the bottom, feel free to view or download.
Shock Matrix
The following fields highlighted in yellow are adjustable.
- The 'Ride Height' field uses my JLR as a base, but your Jeep may ride differently. Be sure to check the shock eye-to-eye measurements for accuracy.
- 'Bump Travel' (or Up Travel) just turns some of the text red that is outside of the recommended range
OEM Springs: a never complete list of all the spring combinations
Rear Motion Ratio: shows how the rear shock's response isn't linear to suspension travel, and most important at lower ride heights
Spring Rates: a small list of spring rates I have collected from this forum
Caster: another small list, this time of caster measurements using fixed arms
Wheelbase: comparing the JL to other Jeeps
Breakover: how the JL & JT breakover angles change at various heights
