Shock Recommendations for 2.5" lift
quick66
quick66
Ken
North Georgia
2022 Jeep Wrangler Unlimited Hightide Edition
Thanks much appreciated!
quick66
quick66
Ken
North Georgia
@Tyler225 did you run the RK adventure lift with your stock XR wheels and tires? If so did you get any rubbing with the control arms provided with the kit?
Tyler225
Tyler
2022 JLUR XR
Only on the highway for about 50 miles so unfortunately no idea if there would have been any rubbing
Roky
Roky
Yes they will rub slightly at full lock..you can adjust out the turn stops, but not sure if it will be enough….. some use wheel spacers.. For a 37 tire you need 4.5” back space or less.
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
J0E
J0e
bt39.com
hoag4147
Colleyville, TX
2022 JLUR XR
Roky
Roky
Just curious - So the 3.5-4” shocks pushing it to keep the 2.5” springs seated? I know your running 4.5-6” shocks with 3.5” springs and they stay in place.
They would stay seated….. but considering what the OP said is use was, there’s no need for the extra droop and less uptravel. Had he said he is more 50/50 on/off road, I would recommend the 3.5-4s ……
hoag4147
Colleyville, TX
2022 JLUR XR
Good point. Although less uptravel in front shouldn’t be an issue with those wonderful long bump towers 😂
Can’t remember specs on 3.5-4s but front driveshaft may become concern as well I guess.
Roky
Roky
28.4 extended, 17.8 compressed……for 3.5-4s and 26.25 ext, 16.75 comp. for the 2-3s …….
Poordad
Marc
Santa Clarita, Ca
2013 Acura TSX, 2015 Chrysler 300s, 2023 JLUR
I had a 2.5 inch RK lift on my JK. I first used Bilstein 5100 shocks, then later put on Rancho
RS9000XL adjustable shocks after that. Both were good for my uses, with the Rancho's being a little better. Both should be around 400 bones, maybe a little more for the Rancho's.
quick66
quick66
Ken
North Georgia
I actually just installed some Rancho 9000XLs about a month ago. The problem I was trying to solve/minimize was having the front end bottom out on the ridiculously long jounce tubes that come on these XRs. While the new shocks did help and definitely are an improvement over the stock shocks, the problem is still happening. As far as running the Ranchos with the Rock Crawler lift... The Rancho shocks don't have near the travel that RK recommends. Hence the reason for the post.
Roky
Roky
Keep in mind that RKs recommendation is to maximize full use of the springs when articulating off-road. It has no bearing on the highway. If you’re 80/20 on/off road and are just doing moderate trails, you can run any length shocks you want as long as they don’t bottom out, or over extend….
quick66
quick66
Ken
North Georgia
Understood. The Rancho shocks I have would limit travel in both directions:
Front RS999065 - 18.16"/25.21"/7.05"
Rear RS999066 - 19.89"/28.59"/8.7"
