Set OEM halo lights to turn on when I switch to parking lights?
Schmeegz
Jesse
Buffalo, NY
2018 JLUR (Ocean Blue Metallic)
Does anyone know if there is a way to include the OEM halos to turn on when I switch to parking lights? (It’s currently just the fender lights)
Jeepsterfreak
Honda, Future JLU
So the halos are only on when the headlights are on? I wasn’t sure if the halos worked as DRL or not.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
I'm currently away from mine and can't check, but isn't there a setting on the uconnect that turns the halos on and off? My halos are always on with the fender lights for drl mode, they stay lit during running light mode, and remain on with full headlights. The only time the halos aren't lit is if I remote start it. I've noticed that only the white fender lights and the rear lights are on until i hit the start button, then the halos light up and the rear goes dark.
Schmeegz
Schmeegz
Jesse
Buffalo, NY
  • Thread starter
  • Thread Starter
  • #5
Right. I’d like to turn the dial to parking lights and the halos come on
BWWJL
Chicago Area
18 JLU Sport S
Tazer?
cns721
Rochester NY
'04 WJ, '13 JKU Sahara, '18 WK2 High Altitude, '19 JLUR
Software Developer
I'm pretty sure the halos do come on for me when I turn on the parking lights.
smithrd65
San Antonio
2018 Jeep Wrangler Rubicon Unlimited JL. BMW Z4 35is, Tesla Model X90D, Chevy 2500 LTZ
Yes they do check your settings
Don't use the silly Tazer.
Schmeegz
Schmeegz
Jesse
Buffalo, NY
  • Thread starter
  • Thread Starter
  • #11
there is no settings for the parking lights in the settings
BillG
Bill
Middle Tennessee
2018 Sting Gray JLUR / 15 Harley Tri glide / 50 Dodge Rat pickup
On my seven inch, on the radio I go to settings, push the down arrow to the second screen, then click on lights for various choices. Maybe what you want is in there.
Schmeegz
Schmeegz
Jesse
Buffalo, NY
  • Thread starter
  • Thread Starter
  • #13
Yeah I’ve already been through that setting. Thanks tho
Jeepsterfreak
Honda, Future JLU
I honestly don’t know if there are halo settings in the UConnect. I see the DRL setting that can be turned off/on, but that only turns off the fender DRL. The Halos stay on.
If your Halos turn off when you turn on parking lights, then maybe you have a problem. In the video above, he turns on the parking lights at 2:00 to view the rear tail lights, then at 2:25 he shows the front parking lights on with both fender/side marker and halos on. At 3:13 he turns on the headlights and halos are on.
Actually it seems the Halos are always on. There was a forum member awhile back wanting to turn off the Halos but could not find a way.
I am assuming your JL was equipped with the LED option from the factory and you did not install take offs later which may require BCM programming by the dealer.
Bravo
Eric
Meridian, ID
2020 JLUR 3.0, 2016 Dodge Ram 2500 Mega CTD, 2019 Roadglide Special, 2015 Malibu Wakesetter 23 LSV, 2019 Skidoo Summit X 165, and 2018 Skidoo Summit X 154
My halos are on regardless of switch position....
Bravo
Motor City Aftermarket
