How many times are you going to have to get an extra 18 miles for $1 to pay for the extra $6000 the diesel costs over a V6 with a manual? The diesel Wrangler is cool because it's torquey as hell but buying one for the gas mileage does not make much sense considering the additional upfront and maintenance costs.You got to remember though, the Wrangler EcoDiesel has a 18.3 gallon fuel tank. The 3.6L has a 21.5 gallon fuel tank.
Here where I'm at in North Texas, diesel fuel is running around $3.45, regular gas fuel is running about $2.89.
18.3*3.45=63.135
21.5*2.89=62.135
Now obviously that's different depending where you live.
You do some more math, you get 384.3 miles on a tank of diesel, and 365.5 mi on a tank of gasoline. Which actually is pretty dang comparable, considering I'm only spending $1 more for diesel fuel to get an extra 18 mi out of a tank. The biggest difference though is that if I just slow it down to 65 mph, I can pull in 24 mpg easy. I also idle a lot more than I really should. The few times I've stopped idling and driven 65 on a tank, I've averaged 26 mpg (475.8 miles per tank).
Good luck beating that number!!!
For curiosity's sake, I researched that very subject when I was deciding which trim I wanted for my JLU. These are the MY2019/20 vehicles that meet your stated requirements:Low tech is one of the major reasons I purchased my Wrangler. You show me another 2019+ model year vehicle where I can get manual windows, manual locks, and a 5" non-navigational touch screen.
Don't forget about the $40 OEM fuel filter, and the $80 OEM oil filter. Actually the maintenance costs are not as bad as people first thought them to be. Without getting into too much detail, I just purchased a fuel filter on Amazon for $18. I bought a second gen EcoDiesel oil filter cover for $22, and a second gen oil filter for $6. The second gen and third gen oil filters are backwards and forwards compatible. All future oil filters will cost me $6 at this point. I can get 10 quarts of full synthetic oil (only need 9qts) for $60. If you're ballsy enough to do an EGR and DEF delete, not only will your oil be cleaner, you'll never have to worry about the cost of DEF fluid ever again. You can also turn your DEF tank into a spare fuel tank. Carry an extra 5 gallons!How many times are you going to have to get an extra 18 miles for $1 to pay for the extra $6000 the diesel costs over a V6 with a manual? The diesel Wrangler is cool because it's torquey as hell but buying one for the gas mileage does not make much sense considering the additional upfront and maintenance costs.
How many of those are designed from the factory to go off-road?For curiosity's sake, I researched that very subject when I was deciding which trim I wanted for my JLU. These are the MY2019/20 vehicles that meet your stated requirements:
Ford F150 (XL trim)
RAM regular cab 1500 Tradesman
Nissan Frontier (S package)
Chevy Spark (LS trim)
Nissan Versa S
I wasn't actually debating anyone in that comment, I was just trying to get across the point that Wranglers are special.@Tredsdert
I don't know who you're debating, Greg, but it isn't me. I simply provided, in isolation, a short list of those vehicles that still offer manual window and door lock controls. I do agree that the Wrangler community is singular and unique, but that's an entry for a separate ledger.
Here's a Coors Light, on me.
Are they though? Even if you ignore maintenance it's going to take a million miles before the EcoDiesel breaks even.Don't forget about the $40 OEM fuel filter, and the $80 OEM oil filter. Actually the maintenance costs are not as bad as people first thought them to be. Without getting into too much detail, I just purchased a fuel filter on Amazon for $18. I bought a second gen EcoDiesel oil filter cover for $16, and a second gen oil filter for $6. The second gen and third gen oil filters are backwards and forwards compatible. All future oil filters will cost me $6 at this point. I can get 10 quarts of full synthetic oil (only need 9qts) for $60. If you're ballsy enough to do an EGR and DEF delete, not only will your oil be cleaner, you'll never have to worry about the cost of DEF fluid ever again. You can also turn your DEF tank into a spare fuel tank. Carry an extra 5 gallons!
I do agree with you to a certain extent. Sure the EcoDiesel was a $6,000 added cost when I bought my Wrangler. But my Willys Sport EcoDiesel still came in at $43,000. By your comparison, a $47,000 base model Rubicon with manual transmission is a terrible purchase.
Wranglers aren't cheap, but at the fuel pump (at least in Texas) EcoDiesels are winning!
A base model Willys Sport doesn't get 26 mpg. If you want 26 MPG out of a Wrangler JLU, you should buy an EcoDiesel. The maintenance cost of an EcoDiesel Wrangler isn't proportionately higher than a 3.6L. If spending $6,000 more for an EcoDiesel engine isn't worth it to get an extra 110 mi out of each tank of fuel, then buying a $47,000 Wrangler Rubicon to get 110 less miles out of each tank should be significantly worse than the $6,000 you would spend on the EcoDiesel engine.Why would you compare the price of a Willys Sport EcoDiesel to a base model Rubicon? A base model Willys Sport is a direct comparison and would have come in at $37,000.
Diesel in NY is well over $5/gallon
You and me both brother, you and me both!I love my Jeep. It gives and gives. It provides me with endless repair and modification tasks... which I need to keep me from having to do my wife's list of tasks.
