rizej
- Jared
- Feb 28, 2018
- Denver, CO
- 2018 JLUR
I don't have an OBDII reader otherwise I would provide the codes but it's the same circumstances each time: While in 4H (not sure if it applies to 4L since most of my trails are in 4H), both the Service ESC & ESS Disabled light come on after some time on the trail. It's not within the first couple minutes but maybe 30+ minutes depending on the trail. Continue on the trail and then shift back in 2H and the lights remain on. Once I turn the vehicle off, both ESC & ESS lights are gone.
I know a few people on here have gotten the same exact problem but I haven't seen an actual solution. There are other issues with the ESC only that seem to happen even during everyday driving. This seems to be different since it only happens while in 4H...
EDIT: I've also mentioned this to the Service dept. when I was there for countless other things (U62 recall, Hard Top Seal replacement, etc.) and the tech said he would see if any codes were stored and unfortunately there were none. They said they looked at the Vacuum pump but I honestly don't think they did a single thing
