Service Electronic Throttle Control Resolutions
Amaruq
Atlanta
JLR 6spd
Not sure exactly, but I think the TPS got hot because the radiator fan hasn’t been coming on. I’ve only heard it for a few moments (before this issue started) between two days of 4Lo driving in the San Juans.
JimLee
'19 JLU
You gonna be able to get it off the trail? I think if you turn the AC on max, recirculate, fan as high as it will go it forces the cooling fan on but that may not be comfortable where you are at. You are also adding a load and potentially more heat under the hood so cautious with that approach.
Amaruq
Atlanta
JLR 6spd
I did make it off after 30 minutes of it shut down to cool. No further issues. Indeed odd that the rad fan is not coming on though. Will get that looked at.
JimLee
'19 JLU
Cool, glad you made it out ok. I stumbled across the other thread you were posting in also. Hopefully the rest of your trip goes well.
zeebo56
Zee
los angeles
2020 jeep wrangler unlimited sport
So my warning went off today and it turned out to be my steering wheel being off center. Last weekend I had changed the front track bar and was planning on doing the toe correction and steering wheel correction next weekend.
Message came up today and wouldn't go away so I tried the drag link adjustment and it fixed it.
Not saying it is what's wrong with yours but for others it is a quick thing to try other than pushing down on all the fuses to make sure they are all seated well.
D60
CO
JL
I'm gonna guess you had ESC errors not ETC issues. Yaw has nothing to do with with throttle position.
Incidentally, you might be able to eliminate ESC errors by going to "stage 2" of TC kill - hold the button for 5+ seconds while at a stop. My '19 does seem to disable everything but it throws "Service" errors for TC, ESC and ABS which don't go away until I shut down and restart. The manual says you can return to TC on by simply pushing the button again but my JL instead chooses to panic (hey, kinda like COVID!) and throw a bunch of errors.....but again, I do think it's disabling all the nannies simply because all the error lights come on and stay on.
D60
CO
JL
Mine hardly runs at all in 4lo in the mountains. Ironically if the digi display is to be believed it runs 222 on the highway and will run 190 all day long crawling in the mountains, even with the AC on
Also I recently managed to drive up a good portion of Blanca with my parking brake on (ya see....I'm just so good I had to make it more challenging....yeah that's it) and during that time the fan was running WAY more despite coolant allegedly being 185.
Thus I'm pretty convinced FCA also uses an engine load algorithm to determine when to kick on the fan, not just a thermal switch. I've never seen such a theory discussed on the forum but I'm convinced I'm right. And when you're crawling in 4lo even though it might seem like the engine is working due to the higher RPM the fact is that it's not due to all the gear reduction
And hey, you know you should always trust theories from idiots on the internet wise enough to drive up one of Colorado's most difficult old-school trails with his parking brake on...I even made it through Jaws 3 no problem like that.....I'm just that dumb -- er I mean GOOD
zeebo56
Zee
los angeles
Shoot you are right, it was stability control error. My bad. It was late and I was about to pass out.
WVJEEPZ
Summit Point, WV
2021 Jeep Wrangler Unlimited Rubicon ecoDiesel
I just experienced this error along with the check engine light while towing a small trailer up a long grade The accompanying reduction in power while on a 70 mph freeway is a hazard in and of itself.
WVJEEPZ
Summit Point, WV
My 2021 Wrangler JLU Rubicon EcoDiesel is in getting a turbo replacement right now! The scary part is they stated they had to remove the cab to perform the work. Does anyone have access to the service manual? Removing the cab sounds a bit extreme.
Hawknz8
Steven
Oklahoma City
2020 JLU Rubicon ecoDiesel
Removing the cab has become ever more increasingly common on a lot of cars, it doesn’t surprise me on the ecodiesel as it becomes more and more crowded under the hood.
