ChiefJL
Hello!
I installed my Tazer Mini last night and made the following changes:
- tire size to 37"
- hood alarm on
- turn signal cam on
- disabled the park when moving door open
-disabled TPMS
I did a reboot and 2 sleep cycles as outlined in the instructions.
About 15 min later I took my JL to the store to test the accuracy of the speedometer. When I pulled out of the driveway the Serv 4WD light came on once I was in drive, however, the TPMS and turn signal cam and speedometer seemed to work fine. I went into the store, came out and drove home and the turn signal can stopped working, as did my backup cam. In its place was a blue screen that I believe said Video System Unavailable and the Serv 4WD light turned on again once in drive. I went home and did a full reset, which fixed the camera issue, but the serv 4WD light has remained. Any suggestions on which settings I should check (admittedly I may have unintentionally changed a setting, but I didn't access the Offroad menu, so I'm not sure how likely that is)
I should note that this is a week old 21 JLUR for reference and that I did update the Tazer to the most recent firmware prior to installiny.
Any help or insight would be greatly appreciated!
- tire size to 37"
- hood alarm on
-disabled TPMS
