Security bypass cable question
mixdup
Atlanta
2024 Unlimited Rubicon
So I finally got around to getting a security bypass cable so I could set the proper tire size in my 22 4xe with JScan. My question is, is the security module used for anything other than securing the OBD-II port?
It's kind of a pain with a bracket in there, so I thought about just leaving the bypass cable in there but wasn't sure what that might affect or do to the Jeep day to day
Gregj
Greg
West Texas
If you take it in for service you will need to hook it back up, otherwise no problem.
Gregj
TrentYoung
Trent
Phoenix
2024 Jeep Wrangler Rubicon X 4Xe
I put my security bypass cable in two years ago and I have never had an issue with the Jeep dealer. I 100% leave it in there and hooked up.
AndySpill
Andy
Pittsburgh
2018 JL Sahara
Which cable are we talking about. The SGW Extension or 12+8 security bypass for Jscan and an ODB II port reader?
My SGW Extension remains, connected to a Tazer but Jscan goes with a 12+8 cable (doesn't it?) that needs to get removed and the factory 12 and 8 pin plugs replugged in after, no?
AndySpill
Andy
Pittsburgh
2018 JL Sahara
Terrymo
Terry
2023 JLURXR 3.6 ET
Here is my basic and maybe incorrect understanding. The Z automotive SGW extension cables do not need to plug into the Tazer. They are there as an extension cord for when the Tazer is removed and the OEM wiring harnesses need to be plugged back in. I attach an ECRI module into the security gateway OEM connectors with a Bluetooth module in the OBD port. Once I’m done with JSCAn programming, the Tazer plugs into these same OEM connectors and stays plugged in after I’m done. The Z automotive extension harness only gets plugged back into the factory connectors when going to the dealer with the Tazer and JSCAN removed from the vehicle. I’m sure my wording and descriptions are not as clear as what I linked from @Rhinebeck01
LAM
Larry
Bay Area California
2022 Sahara 4XE
THAW
Foster
23 JL4DrRubicon
A Tazer bypasses the security gateway, therefore when it's plugged in JScan can be used via a Bluetooth OBD-II adapter (without the need for a bypass cable).
Terrymo
Terry
2023 JLURXR 3.6 ET
Ok these two connectors in the picture are unplugged and plug into the Tazer. If I use JSCAN I plug the two connectors into the ECRI module and the JSCAN bluetooth adapter into the OBD port. Are you saying with the two OEM connectors plugged into the Tazer, the ECRI module that the OEM connectors plug into is unnecessary?
Jeep Wrangler JL Security bypass cable question IMG_3960
THAW
Foster
23 JL4DrRubicon
Yes, the ECRI is unnecessary; your Tazer already allows you to use JScan via a Bluetooth adapter in the OBD-II port.
Doesn't the ECRI have other features though?
Terrymo
Terry
2023 JLURXR 3.6 ET
@THAW
Well hell…thank you. I’ve been switching back and forth between the ECRi and Tazer modules needlessly then.
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
What BT adapter do y’all use for JScan? I’m thinking about installing one in my wife’s Jeep.
